blitz dual turbo timer
Old May 24, 2009 | 11:50 AM
turbohatch96y7's Avatar
Icon3 blitz dual turbo timer
how accurate is the boost gauge on a blitz turbo timer.
is it accurate enough to just use the blitz instead of getting another gauge.
thanks
Old May 24, 2009 | 12:01 PM
Default Re: blitz dual turbo timer
Old May 24, 2009 | 01:02 PM
ghg
Old May 24, 2009 | 02:36 PM
anyone know
Old May 24, 2009 | 03:23 PM
222
Old May 24, 2009 | 07:33 PM
525
Old May 24, 2009 | 07:53 PM
TheShodan's Avatar
Moderator
It is always best to use a vacuum based gauge in conjunction with the timer.... Using both is not a problem
Old May 24, 2009 | 07:58 PM
okay cause this is a dual timer it has a vacum line in the back..
i was asking cause id rather have less gauges for a less chance of getting jacked
Old May 24, 2009 | 08:11 PM
beyondstock's Avatar
the blitz is most deffinatly accurate enough to use alone in boost monitoring... If it wasnt then the system wouldnt regulate boost correctly. however its hard to look down at your dash to see what boost you are running when pounding through the gears...
Old May 24, 2009 | 10:58 PM
got it thanks alot...
yeah the timer has like an overboost protection on it so if there is a boost spike it changes bright red... thanks alot
EJ8 GSR-T
Jan 8, 2006 04:29 PM
EM2Civic
Dec 10, 2004 12:02 AM
ceemarun
Aug 27, 2002 04:00 PM
grnsol
Feb 22, 2002 06:35 PM
tararan
Nov 16, 2001 02:09 PM
