turbo surge point
Old Sep 15, 2008 | 07:47 PM
turboek97's Avatar
Default turbo surge point
is it possible that my turbo could be at its surge point during acceleration? what can i do to prevent it? when the engine is under a load at lower rpms the boost gauge jumps back and foward over about a 5psi range and it also sounds like the wastegate is fluttering? i checked all the plumbing and vaccum lines and everything seems to be tight. i just baught a new bov and i took the wastegate all apart cleaned it up and lubed it and seems to be working properly. im stumped........no idea whats wrong
Old Sep 15, 2008 | 10:02 PM
CRXdan's Avatar
Default Re: turbo surge point (turboek97)
What turbo on what engine? Its usually caused by too large of a turbo, but if you have surge like that you must be running a massive turbo with small turbine housing.
Old Sep 16, 2008 | 08:12 PM
turboek97's Avatar
Default Re: turbo surge point (CRXdan)
its a T04E turbonetics turbo,turbonetics evolution wastegate, vortex bov, treadsone plumbing & fmic, 450cc inj. chipped ecu at 9psi
Old Sep 17, 2008 | 02:34 AM
CRXdan's Avatar
t04e means nothing. what trim, ar of turbine housing, and engine?
Old Sep 17, 2008 | 08:12 PM
turboek97's Avatar
stock b18b1 60 trim .48 ar
qpe
Nov 29, 2010 09:32 AM
AutoLab
Jul 27, 2009 07:09 AM
Orangecivic251
Dec 19, 2006 07:58 PM
jared99
Nov 27, 2005 07:31 PM
