garrett compressor wheel
Old Sep 12, 2009 | 03:37 PM
EKlscoupe_98's Avatar
Default garrett compressor wheel
ok so i bent a blade on my garrett turbo and im trying to find a part number or some where to get a new compressor wheel, its a 57 trim with .63 exhuast housing. any help would be great...
Old Sep 12, 2009 | 04:54 PM
ScorpionT's Avatar
Default Re: garrett compressor wheel
Basically, you need a whole new chra.
Old Sep 12, 2009 | 11:58 PM
tokesGTR's Avatar
If it's not a ball bearing turbo it can be replaced. It'll need to be rebalanced though, so your best bet is to send it off to a repair centre.
Old Sep 13, 2009 | 08:07 AM
ScorpionT's Avatar
True. I was under the assumption that it was ball bearing. Long day.
Old Sep 13, 2009 | 03:41 PM
ok its not BB. Why would i need to rebalance the turbo if i change the wheel. Cant i just take the nut of pull the wheel and slap another one on.
Old Sep 13, 2009 | 04:28 PM
tokesGTR's Avatar
Why do turbos need to be balanced in the first place, if every wheel is the same? There's obviously a weight range within tolerances for every wheel. A different of a few fractions of a gram becomes a massive amount of weight imbalance when you're spinning a turbo at 100 thousand RPM's. But Garrett can't make every single wheel to be perfectly balanced because A) They are going to be paired up with different shafts and turbine wheels and B)Ensuring every wheel itself was spot on instead of balancing the whole assembly would be much less cost effective.
Old Sep 13, 2009 | 05:48 PM
HiProfile's Avatar
Compressor wheels are usually staticly balanced, but relatively roughly. They also have to balance it with your turbine wheel after mating them. They can't fully balance a turbine wheel alone, because there isn't any removable material on one end. W/o rebalancing it, you'll ruin the bearings after a few thousand miles, if not before one hundred.
Some places will just balance the turbo on a VSR maching, I recall seeing one recently for $60. More than likely the same place will be able to get you a wheel AND torque it properly for a decent price. Expect ~$100-150 for a non-chinese compressor wheel.
Old Sep 13, 2009 | 06:56 PM
thanks for the helpful info. anyone recommened a shop to do this? Or maybe this is a sign to upgrade turbos seems im at my limits with this one... anyone with a good 30r or 67 h.o
Old Sep 14, 2009 | 06:01 AM
EARLdaSQUIRREL's Avatar
official honda whore
theres a huge difference between those 2 turbos!!
and like i told you, just send it to blaast performance if you want to keep it, its your cheapest option and will make 430+whp
Old Sep 14, 2009 | 11:55 AM
ScorpionT's Avatar
Blouch is near you, I recommend them. ATP Turbo is also very good.
Jianshatch
Jun 13, 2017 09:08 AM
civic92si
Sep 19, 2010 01:36 PM
912
Nov 3, 2009 06:20 PM
booscivic
Sep 25, 2006 07:50 PM
