Turbo, Spool Times, Ect
Old Sep 26, 2005 | 07:41 AM
digital sol's Avatar
Default Turbo, Spool Times, Ect
gsr bottom end, 84mm bore, 9:1
itr head
log manifold
itr cam's
was curious to know what the spool time is like on the
57trim-
sc34-
sc61-
sc50-
looking for a good street turbo that spools quick but can pull to a 8.5k redline. Powergoal is 300whp low boost but i want useable power not peak numbers, probably around 400whp highboost. I think the sc61 is probably to big for my goals, the max power i plan to ever do is around 400whp on high boost. Just looking for the right turbo for my needs. Something that can spool on the quicker side but pull hard all the way to about 8.5k. Ill be usuing an 4.785 ITR tranny as well. looking for 300whp as my daily driver setting, and 400whp as track boost level
btw: car will always be on pump gas, basically gonna tune what ever turbo i decide on to around 300whp for my daily driver setting, then try to get what ever i can upwards to 400whp on pump gas for my high boost setting.
Old Sep 26, 2005 | 07:59 AM
The Weather Man's Avatar
the sc61 would make tremendous power. Thats the one i'm going with. It'll make power maybe around 4800-5200 - but its well worth it.
Get a nice valvetrain - so you can rev to 9000........get a lightened flywheel so you can get there quickly - make sure your bottom end is on point.......and it'll be WELL worth it. There is a dyno somewhere comparing the sc61 vs a t3/t4 turbo - the sc61 made so much more power than the t3/t4 on the same PSI.....it was great.
Old Sep 26, 2005 | 08:29 AM
turbotime's Avatar
not sure what trim and ar my stuff is but i got a t3/t4 on a built b17 @8.5:1 CR
I made 200whp on a dynojet with a broken distributor.
Turbo spools fully around 4.5 and pulls hard as **** right out to 8.5
Old Sep 26, 2005 | 09:59 AM
turboH22Aakkord's Avatar
Default Re: (TheKingPin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheKingPin &raquo;</TD></TR><TR><TD CLASS="quote">the sc61 would make tremendous power. Thats the one i'm going with. It'll make power maybe around 4800-5200 - but its well worth it.
Get a nice valvetrain - so you can rev to 9000........get a lightened flywheel so you can get there quickly - make sure your bottom end is on point.......and it'll be WELL worth it. There is a dyno somewhere comparing the sc61 vs a t3/t4 turbo - the sc61 made so much more power than the t3/t4 on the same PSI.....it was great.</TD></TR></TABLE>
sorry... dont mean to thread jack, but does the sc61 have a t3 or t4 exhaust side flange? thanks...
Old Sep 26, 2005 | 10:02 AM
turbotime's Avatar
t3 i think, of course im guessing
Old Sep 26, 2005 | 10:36 AM
Default Re: (turbotime)
isnt there diff versions of the sc61 with bigger/smaller ect
which spec version should i go with?
Old Sep 26, 2005 | 11:10 AM
Honda_Tengoku's Avatar
Default Re: Turbo, Spool Times, Ect (digital sol)
sc34 is my vote. or sc44. agree here that the sc61 might be too big with your gearing. just my thoughts. good luck.
Old Sep 26, 2005 | 10:03 PM
TheShodan's Avatar
Moderator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by digital sol &raquo;</TD></TR><TR><TD CLASS="quote">gsr bottom end, 84mm bore, 9:1
itr head
log manifold
itr cam's
57trim-
sc34-
sc61-
sc50-
btw: car will always be on pump gas, basically gonna tune what ever turbo i decide on to around 300whp for my daily driver setting, then try to get what ever i can upwards to 400whp on pump gas for my high boost setting.</TD></TR></TABLE>
I use the 4.785 final drive and love it. I think the GT3255 would be perfect for that setyp with the goals that you're seriously looking for. I guess I'm just not an SC61 fan because of its Peaky characteristics that I experienced in 5 cars.
adam00
Dec 23, 2008 10:46 PM
JSiRTO
Oct 9, 2006 04:22 PM
digital sol
Jul 4, 2005 12:14 PM
ek9turbo
Dec 2, 2003 01:07 PM
bigwig
Oct 4, 2003 10:23 PM
