Turbo size b16?
Old Oct 27, 2009 | 08:03 AM
Alli's Avatar
Default Turbo size b16?
Hi. I am considering converting my stock b16 block to FI. I got a lot of turbo options and i was wondering if anybody could post some dyno sheets with different turbo specs. My first choice was to use a Skyline GTR t28 for quick spoolup with ar .64 compressor housing ported to 3" and rebuilt to steel turbine wheels (from ceramic). My goal is around 170-200whp. My only worry is that the wastegate is to small for running around .5bar. Don't want creeps. Anyone tried this?
Sorry for my bad english (norwegian )
Thx
Old Oct 27, 2009 | 09:09 AM
oneludesol's Avatar
GDD's Dr. Phil?
Community Builder
Default Re: Turbo size b16?
t3 super 60
Old Oct 27, 2009 | 12:11 PM
Alli's Avatar
When will this spool up? You got any dyno sheets?
Old Oct 27, 2009 | 12:15 PM
K20egcw's Avatar
My friend had a T3/To4e on a stock B16 with a street tune and that thing moved! I cant remember when it hit full boost, but it was fairly early (thinkin around like 4-4500?)
oneludesol's Avatar
GDD's Dr. Phil?
Community Builder
no sheets, but LS motors have full spool around 3k...
Old Oct 27, 2009 | 12:20 PM
Alli's Avatar
Yeah but an ls motor generates an awful more exhaust than b16. I would think that t3 super60 would spool up around 4500-5000ish
Old Oct 27, 2009 | 12:30 PM
oneludesol's Avatar
GDD's Dr. Phil?
Community Builder
no fing way, especially a .48, the ls was on a .63
Old Oct 27, 2009 | 01:04 PM
Alli's Avatar
But the problem is that the guy i am bying the turbo of only deals garrett. Got another alternative?
Old Oct 27, 2009 | 01:07 PM
mytj2000's Avatar
I think a super 60 would work fine .48 , had one on my LS and started to spool around 2,600rpm
Old Oct 27, 2009 | 03:45 PM
oneludesol's Avatar
GDD's Dr. Phil?
Community Builder
The super 60 is a Garrett unit
Old Oct 27, 2009 | 06:05 PM
SIXTY-1HATCH's Avatar
I run a garrett t3 60-1, it's a good mild turbo, good for street/strip car. They max out around 5-550hp, so it depends on what exactly your doing with it, whats the purpose? Mine is the larger one .82a/r, but honestly they all spool about the same. Mines on my 2.0l gsr and it sees boost around 35-4k, and full boosts when vtec hits, 5200. See my sig. for times on low boost (16-18psi). If your not looking to make alot of power, I would suggest a t3/y4 57 trim. I had one of those on my stock 200,000 mile ls motor, and it was the ****!! Car would be FULL BOOSTING right around 3k or so, it was the best street car by far! I think they max out around 450 though depending on which one you get. I would get the biggest version of it. ACTUALLY there is a thread in drag racing i think, for a 57 trim that just broke into the 10's, so its doable, but again just depends on what your plans are with this thing.....Hope that helped some....
Old Oct 28, 2009 | 01:26 AM
Alli's Avatar
My goal is a mid power daily driver. 200whp is enough for me. You think the gt28r is to small?
Old Oct 28, 2009 | 04:03 AM
oneludesol's Avatar
GDD's Dr. Phil?
Community Builder
if you are only after 200whp, and want instant boost, why don't you go with a Jackson Racing Supercharger?
Old Oct 28, 2009 | 04:24 AM
Alli's Avatar
Because i get the turbo for free.
Old Oct 28, 2009 | 11:22 AM
Alli's Avatar
Anyone got any experience with the GT28R on stock b16a2?
Old Oct 28, 2009 | 12:11 PM
TheShodan's Avatar
Moderator
for 200whp, that's not a problem with a GT28R. You'll probably need a boost controller to help with that, but that would be rather fun. Like a big NA car. the engine size works quite well with that turbo. In fact, the turbo may light up tooo quickly making you spin a lot of tire fast. It's not AWD, so you will more than likely experience some torque steer
Old Oct 28, 2009 | 01:44 PM
Alli's Avatar
Thanks exactly the answer i was hoping for. Mayby i will increase the pressure later but for now i am looking for a steady daily driver. Thx
Old Oct 28, 2009 | 06:43 PM
eg_21's Avatar
i had it on my 93 si d16z6 and it was quite fun, 7 psi was great 12psi the **** never did more than 12 psi but i would be a good turbo for a b16 just get a boos controller.
Old Oct 29, 2009 | 04:40 AM
project dc2's Avatar
t3 super 60 woudl be good if you only want 200 out of it ..
xchipx
Mar 13, 2010 06:55 PM
airforce21
Oct 7, 2009 01:26 AM
crxfreak1117
Feb 3, 2009 11:31 AM
civic_66
Nov 14, 2006 02:30 PM
Meet07
Mar 28, 2006 11:06 PM
