Turbo setup without an intercooler?
Old Feb 29, 2008 | 12:27 PM
carma42's Avatar
Default Turbo setup without an intercooler?
No flaming. this will only be temporary until I can get more money to intercool it all but i want to start off with a turbo setup on very low boost, like 6 to 8 psi on a B18B and I just want to bolt up a turbo to a down pipe, then feed the turbo up to my intake manifold with a blow off valve inline. Very basic description but you should be able to figure out what i want to do anyway. .lol. If this is an ok setup to do on low boost then about 6 months or so down the road finish it all and maybe boost around 10 - 12 psi then let me know.
Old Feb 29, 2008 | 12:37 PM
mangina's Avatar
please dont.
if you dont have money for a complete turbo system wait till you can afford one.
save money
Old Feb 29, 2008 | 12:44 PM
carma42's Avatar
Default Re: (mangina)
I just wondered what the side effects are if any because everywhere i have read in the past 30 minutes has said it is completely fine under very low boost like i am talking. Just looking for some sort of an explanation behind either theory. Thanks
Old Feb 29, 2008 | 12:54 PM
Death_to_Thieves's Avatar
Default Re: (carma42)
dude they have intercoolers on Ebay for cheap. Hell, I have a spare Drag intercooler for cheap that I will sell you if you want.
Old Feb 29, 2008 | 01:11 PM
Snailed EF's Avatar
Default Re: (JAYSEM Society)
Just buy a used one for cheap. dont skimp on anything or you will regret it.
Old Feb 29, 2008 | 06:35 PM
hatchkid91's Avatar
dont think you thats you should run a turbo with out an intercooler justed buy a used one off on ebay
Old Feb 29, 2008 | 06:44 PM
mitsuman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by carma42 &raquo;</TD></TR><TR><TD CLASS="quote">I just wondered what the side effects are if any because everywhere i have read in the past 30 minutes has said it is completely fine under very low boost like i am talking. Just looking for some sort of an explanation behind either theory. Thanks</TD></TR></TABLE>
Well it will work, and it might even be fine. BUT the possibility for detonation are increased due to the fact that the compressed(hot) air is not being cooled down. So its up to you to take the chance blowing your motor, or spending a few more hundred on an intercooler set up. Even a cheap eBay one would work.
No one can tell you what to do, just what to expect.
Old Feb 29, 2008 | 07:00 PM
FreShEM1's Avatar
intercooler ftw
Old Feb 29, 2008 | 08:06 PM
quicksilver1689's Avatar
i ♥ snails
theres no reason not to run an intercooler, the benefits outweigh the small price 1000x.
Old Feb 29, 2008 | 08:16 PM
blinx9900's Avatar
Default Re: (quicksilver1689)
yeah you can do it, you'll be fine, my friend did this, 5-6 psi from a greddy kit on his d16 with no intercooler for about 6 months, street driven, hell he took it to willow springs like that, it wasent fast but it held together. he has an IC now though.
Old Feb 29, 2008 | 11:02 PM
HondaKyle's Avatar
Default Re: Turbo setup without an intercooler? (carma42)
Youll fry your motor and dont get some cheap-o FMIC from ebay you will end up in the same spot with less money
Old Mar 1, 2008 | 01:50 AM
blinx9900's Avatar
Default Re: Turbo setup without an intercooler? (HondaKyle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaKyle &raquo;</TD></TR><TR><TD CLASS="quote">Youll fry your motor and dont get some cheap-o FMIC from ebay you will end up in the same spot with less money</TD></TR></TABLE>
omg shut the *** up dude, you have no idea what your saying, do you have any experience? do you know how many people used to run the greddy kit without an intercooler back in the day? you probably dont cause you werent into this **** back then and i was, OP you'll be fine, just keep the boost down...
Old Mar 1, 2008 | 05:31 AM
An ebay intercooler will work just fine. I have one and have researched them and found countless other users running them with no issues. Especially since it sounds like he is on a budget, it's his best bet and better than not running one at all.
Like I said in my earlier post, I have a spare Drag intercooler that I will sell you cheap if you are interested. I have no use for it. Good luck either way.
Old Mar 1, 2008 | 05:51 AM
Specail Ed's Avatar
Ha. There is no way running your motor without an intercooler will "fry" your motor. The point of an intercooler is to cool the heated charge coming from the turbo into the intake manifold. A cooler charge with result in more HP, that's a given, not prevent your motor from frying. Intercoolers increase the efficiency of the entire system, without one you'll be less efficient, but you can still do it. Like referenced earlier, the old Greddy kits had an optional intercooler. And how many countless cars are factory turbo'd, running low boost levels, without an intercooler? My mom's Sabb doesn't have an intercooler and has about 160,000 on it and still going strong. Intercoolers help, but are not necessary for what you're looking to do.
Old Mar 1, 2008 | 06:35 AM
HondaKyle's Avatar
Default Re: Turbo setup without an intercooler? (Specail Ed)
Ok ill run my s2000 with no intercooler and while im at it ill turn the boost up
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Specail Ed &raquo;</TD></TR><TR><TD CLASS="quote">
Ha. There is no way running your motor without an intercooler will "fry" your motor. The point of an intercooler is to cool the heated charge coming from the turbo into the intake manifold. A cooler charge with result in more HP, that's a given, not prevent your motor from frying. Intercoolers increase the efficiency of the entire system, without one you'll be less efficient, but you can still do it. Like referenced earlier, the old Greddy kits had an optional intercooler. And how many countless cars are factory turbo'd, running low boost levels, without an intercooler? My mom's Sabb doesn't have an intercooler and has about 160,000 on it and still going strong. Intercoolers help, but are not necessary for what you're looking to do.</TD></TR></TABLE>
Yeah they also have small *** turbos and the turbo isnt under a lot of load but you know every thing so i guess we should just listen to you
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JAYSEM Society &raquo;</TD></TR><TR><TD CLASS="quote">An ebay intercooler will work just fine. I have one and have researched them and found countless other users running them with no issues. Especially since it sounds like he is on a budget, it's his best bet and better than not running one at all.
Like I said in my earlier post, I have a spare Drag intercooler that I will sell you cheap if you are interested. I have no use for it. Good luck either way.</TD></TR></TABLE> really? i guess you just gotta look for the ones with some crappy welds ive only seen a couple
Old Mar 1, 2008 | 07:30 AM
shad0wslay3r's Avatar
My F350 runs 8 psi and doesn't have an intercooler, and it isn't a smaller turbo found in a saab or whatever. If you are just going to run 5 psi you really shouldn't be worried.. I agree with Specail Ed
Old Mar 2, 2008 | 04:12 AM
TDogg Teg's Avatar
LOL! Thats funny.
Old Mar 3, 2008 | 10:44 AM
carma42's Avatar
Default Re: Turbo setup without an intercooler? (TDogg Teg)
All great input guys. Thanks.
Old Mar 3, 2008 | 03:43 PM
blinx9900's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaKyle &raquo;</TD></TR><TR><TD CLASS="quote">Ok ill run my s2000 with no intercooler and while im at it ill turn the boost up
omg go away
OMG go away, he obviously knows more than you and has more expereience than you just like i do.
guess what im gonna say? you guessed it! omg go away!!!!!!!!
Old Mar 3, 2008 | 05:57 PM
DaveF's Avatar
Default Re: Turbo setup without an intercooler? (blinx9900)
http://nyce1s.com/Race%20Video...c.wmv
Old Mar 3, 2008 | 06:02 PM
Bailhatch's Avatar
Default Re: Turbo setup without an intercooler? (DaveF)
Haha^
I ran my d16z6 without an intercooler for a while. 7psi from a nissan t25. It was fine. It didnt knock and I beat the hell out of it for a few months until I put an Intercooler on it.
There are tons of factory turbo cars that don't have intercoolers btw.
Old Mar 3, 2008 | 06:13 PM
hondamn1320's Avatar
Default Re: Turbo setup without an intercooler? (Bailhatch)
my brother-in-law ran his turbo'd ka24de without an intercooler for close to a year with no problems.
i am currently running my b16 turbo without an intercooler until i have enough cash to make a "backdoor" so i can use it. it's running fine and strong with no problems.
Old Mar 5, 2008 | 08:57 AM
dohcdelsol93's Avatar
Default Re: Turbo setup without an intercooler? (hondamn1320)
haha...this thread is funny.
OP you'll be fine. Although if your getting your car tuned without the IC when you go back to install one later it will change the flow of the system and require you to re-tune.
If your plannig on running an FMU then runing without an intercooler is the least of your worries.
ctownintegra
Nov 16, 2006 04:34 PM
twisted_jdm_b16
Nov 6, 2005 08:03 AM
XES
Oct 19, 2005 05:50 PM
rexandfx
May 1, 2004 10:03 AM
Inigo Montoya
Mar 27, 2003 06:23 AM
