TURBO SETUP WITH CTR CAMS
Old Jun 11, 2004 | 07:51 AM
500hpsi's Avatar
Default TURBO SETUP WITH CTR CAMS
As anyone made good HP and torque with CTR cams with a fully built b20vtec motor? If so, what was the power produced and at what psi?
Also is there any cams besides CTR that produces good and have stock idle?
If possible post dyno sheet with type of cam used.
Old Jun 11, 2004 | 09:52 AM
99B16Si's Avatar
the great thing about vtec motors is u dont have to worry about a lobing idle because of the multiple lobes in the cams. as far as ctrs go in my opinion the intake came might be a little to aggressive and cause some nasty overlap but then again that can be fixed with adjustable sprockets. if i were u id sell the CTR intake cam and pick up a GSR or ITR.
no matter which was u choose im sure either way will work fine
Old Jun 12, 2004 | 09:43 PM
500hpsi's Avatar
Default Re: (99B16Si)
I just saw your civic and I the same set up as you. B20-v-tec fully build, 85mm bore and ported head b16. Anyways, what kind of power did you made? cool car too
Old Jun 13, 2004 | 12:53 PM
99B16Si's Avatar
never did race fuel and stopped at 393whp on pump
Old Jun 13, 2004 | 01:09 PM
AMS MIKE's Avatar
CTR cams in a LS/Vtec 2.0L = 550HP+ & 445TQ+ running on 17psi with VP C-16 fuel
AEM EMS
**Note...I am going to try the B16 auto cams, I think they will make a better powerband because they make power sooner!**
mugenDA9 lover
Mar 1, 2007 03:39 PM
slowem1si
11
Nov 6, 2005 04:25 PM
big head
Oct 11, 2005 06:19 PM
BigAnold
Jul 1, 2005 06:33 PM
All Motor EG
May 13, 2002 10:42 PM
