is ctr cams good for turbo????
Old Oct 10, 2005 | 05:34 PM
big head's Avatar
Default is ctr cams good for turbo????
i have a sleeve 84mm b16a engine with a gt30r turbo on it. i just found a good deal on a used set of ctr cams. will that be good on my set up?? anybody using ctr cams on their turbo motors??
Old Oct 10, 2005 | 05:47 PM
areyouasian's Avatar
Default Re: is ctr cams good for turbo???? (big head)
lots of people use CTR cams on their setups and put out great numbers with them.
CTR cams
Old Oct 10, 2005 | 05:59 PM
big head's Avatar
do i need to use cam gears to adjust the cams, because their say ctr cam is too big for turbo and cause the valves to overlap.
Old Oct 11, 2005 | 06:16 PM
Default Re: (big head)
here are some set-ups using type r cams (ctr = 01 itr's) that are putting out 600+ hp.
<U>https://honda-tech.com/zerothread?id=1355442</U>
<U>https://honda-tech.com/zerothread?id=1382007</U>
u can go w/stock cam gears but having adjustable gears will allow you to mess around with the cam settings to see if you can extract more power from your motor.
Old Oct 11, 2005 | 06:19 PM
Default Re: (areyouasian)
wow, i just noticed that the links lead to 2 different cars, BOTH putting out 654whp...LoL!
Topdawgg
Jan 6, 2008 01:34 PM
allstockb18c
Aug 3, 2005 04:39 PM
Mr Aryan
May 7, 2004 06:44 AM
Fuzion
Feb 24, 2004 12:05 AM
B18C2_sedan
Apr 18, 2003 03:33 AM
