Turbo Secrets ?
Old Mar 27, 2004 | 12:10 PM
hitvtecgetloud09's Avatar
Default Turbo Secrets ?
I was just wondering are there any little things u can do to a turbo car to make it even faster with out spending much or no money on?
Old Mar 27, 2004 | 12:11 PM
92jdmhatch's Avatar
Default Re: Turbo Secrets ? (hitvtecgetloud09)
YES, you can put stickers on there.
Old Mar 27, 2004 | 12:12 PM
Default Re: Turbo Secrets ? (92jdmhatch)
****** arg..
Old Mar 27, 2004 | 12:29 PM
5STAR3's Avatar
get a manual boost controler and CRANK IT!!!
Old Mar 27, 2004 | 12:35 PM
int3gra's Avatar
Default Re: Turbo Secrets ? (envision2teg)
expensive options:
get a ball bearing turbo, get it ceramic coated.
i dont know about this but, a full length manifold probably makes it spool better, correct me if im wrong.
Old Mar 27, 2004 | 12:45 PM
Terrabomb's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92jdmhatch &raquo;</TD></TR><TR><TD CLASS="quote">YES, you can put stickers on there.</TD></TR></TABLE>
this post should be deleted.
Old Mar 27, 2004 | 01:18 PM
mamaboy's Avatar
larger ID exhaust system. cheapest alternative if you have a kit on their. besides that everything is money. if you get a Manual boost controller make sure you have enough fuel to compensate for the larger volume of air
Old Mar 27, 2004 | 01:43 PM
Sinner's Avatar
1. hook the wastegate line to the intake manifold instead of the turbo if you havent already dont that, basically gives you a little more boost.
2. hook up a air pump to your charge pipes, block off the front of your turbo and find all those little boost leaks.
3. get a MBC to up the boost, if you have a tuneable fuel system.
4. Exhaust cutout, cheap way to run an open pipe when you want.
5. take the intake pipe from the hot engine bay and relocate it like a CAI. (maybe I'm still havnt done this one, but it seems like it should work)
6. If you dont have an intercooler and BOV go to your local bone yard and pipe one up from a DSM.
7. Run better gas
8. Exhaust wrap, could keep the heat down
djwest24
Sep 20, 2004 07:12 AM
KillerRhino
Jul 6, 2004 06:10 AM
CaptainMorgan
Feb 15, 2004 06:24 AM
mrx
Feb 5, 2004 09:05 AM
b18bturbo
Sep 23, 2002 08:30 AM
