turbo seal going out?
Old Jun 10, 2010 | 09:41 PM
oh_dam's Avatar
Default turbo seal going out?
I'm not sure, but I think a seal on my turbo is going bad. It's a turbonetics t3/t4. Everynow and again, when I stop at a light, or get off the highway, I'll get a cloud of smoke out the exhaust, then it goes away. At first I thought it may also be valve seals, but I just swapped out the motor and it's still doing it. Is this common with seals on the turbo going bad?
Old Jun 11, 2010 | 12:14 AM
turbo gsr2000's Avatar
Default Re: turbo seal going out?
yep check ur i.c Piping for oil
Old Jun 11, 2010 | 12:52 AM
SI_frankenstein's Avatar
Iam having that same problem right now, my car is smoking really bad and there is oil leaking out from the exhaust housing on the turbo.
Old Jun 11, 2010 | 05:52 AM
kyden's Avatar
sounds like you have bad rings.
Old Jun 11, 2010 | 10:28 AM
Axix24's Avatar
Yes.. Bluish smoke? Try using some Mobil 1 15w50 and report back...
Old Jun 11, 2010 | 05:33 PM
oh_dam's Avatar
i cant really tell on smoke color they all look the same to me, but like i can get a video of it smoking sometimes i can just rev it up then let go of the gas and the smoke will just come out i really think it will only do that when in high rpm, but ill try the 15w50 and see
Old Jun 11, 2010 | 05:37 PM
oh_dam's Avatar
well here is a video i found of basically of the same thing it does but i dont have have 2 step
http://www.youtube.com/watch?v=KV6Kocm0Ftw
Last edited by oh_dam; Jun 11, 2010 at 05:38 PM. Reason: did not finish editing it
Old Jun 12, 2010 | 11:28 AM
EFPhilly's Avatar
Just like someone said. Pull the downpipe and IC piping off as well and see. Mine did the same thing. If you roll to stop lights very slow it probably doesnt do anything huh?
Old Jun 12, 2010 | 06:18 PM
gsrturbo'dej1's Avatar
its prolly just the extra gas ur injectors shoot out when ur on the gas pedel and its just being ignited. or if ur not running a braided return line it can be pinched and the turbo is being over filled thats what happened to me
Old Jun 13, 2010 | 02:12 PM
delslow1975's Avatar
just by a rebuild kit and rebuild it nothing to rebuilding it. im sure your going to have oil in your icp. i had a t3/t4 turbonitics 50 trim that did the samething. rebuilt it havent had anymore problems with it.
Old Jun 14, 2010 | 10:20 PM
oh_dam's Avatar
ok so tonight i was driving my car and notice i wasnt building any boost pressure at all and so i went to go look at which icp got loose and it was the one that connects to the turbo and i reach my finger in the inside just to see for oil and yes there is oil, i was wondering how much would a turbo rebuid kit cost.?
Old Jun 20, 2010 | 11:21 AM
EFPhilly's Avatar
Not very much I found the problem being finding a good rebuild kit. My kit for my super sixty was around eighty
smoovy
Apr 19, 2009 11:09 AM
Rooftop voter
Aug 20, 2007 11:33 PM
Rooftop voter
Jul 3, 2007 02:07 PM
BlackDAy
Sep 16, 2005 07:57 AM
Hoosier Daddy
Mar 23, 2004 10:33 PM
