Turbo Screen Option
Old Apr 4, 2006 | 03:00 PM
  #51
methos713's Avatar
Default Re: (Tad)
subscribe for later use.
Old May 19, 2006 | 02:00 PM
  #52
Spec R's Avatar
Default Re: (methos713)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by methos713 &raquo;</TD></TR><TR><TD CLASS="quote">subscribe for later use.</TD></TR></TABLE>
Old May 19, 2006 | 02:16 PM
  #53
EJ1 wilcox's Avatar
Default Re: (Spec R)
Dang this is an old thread.
I was going to say that this topic has been discussed many times before... but this thread IS one of those "times before". lol
Old May 19, 2006 | 03:05 PM
  #54
Tony the Tiger's Avatar
Default Re: Turbo Screen Option (b16hybridsol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16hybridsol &raquo;</TD></TR><TR><TD CLASS="quote">if you put a strong screen behind the k&n cloth and made it bubble out a fewinches from the comp housing, you would see minimal power loss</TD></TR></TABLE>
For some updates...
I actually made a few passes comparing the mesh, full filter, and a mesh with a bulge.
I didn't print out the charts, but the air filter still made the most power. Out of a couple of runs, it was:
Full K&N filter, 4" inlet, 6" length, 5.5" width = 390-392 WHP
Flat Mesh, aluminum window screen = 370-375 WHP
Screen with a nice bulge = 385-387 WHP
It's not 100% accurate because some runs had cool down time, some only rested for a few seconds, etc...
This was on a turbo Toyota Camry with T66 @ 16 PSI
I did the testing mainly because my other car, a turbo Integra, had absoltely zero room for a filter. I wanted to know how much of a power loss I was looking at without a filter and that was my only way to test it by using my other car as a reference.
I barely had enough room to run a bulge on the aluminum mesh, so running a filter is completely out of the question. HKS log manifold I was using did not had the big GT2817R in mind and puts the turbo really close to the block. It's great because I have lots of clearance and enough room for a full size fluidyne with two fans. But shaving the block wasn't even an option because the turbo is snugged right against the block and not the ribbing. The aluminum mesh with a bulge isn't that bad, and I had the engine running like this for quite a long time with minor chipping at the compressor blades. So it's something I can live with.
Old May 19, 2006 | 06:02 PM
  #55
Spec R's Avatar
Default Re: Turbo Screen Option (Tony the Tiger)
as always, great info from tony the tiger.
Old Jan 1, 2007 | 12:54 PM
  #56
djnikko's Avatar
Default Re: Turbo Screen Option (Spec R)
I was looking at the universal K&N filter list and wondered, it best to use a metal or rubber topped filter for my turbo? cheers
LS AzZkIkr
Apr 28, 2011 03:35 PM
tundra2000
Nov 29, 2010 10:52 AM
jon volk
Welding / Fabrication
Feb 22, 2006 07:36 PM
builtB20turbo
Aug 30, 2003 05:43 AM
turboex
Jul 10, 2002 06:45 AM
