Turbo Screen Option
Old Sep 1, 2005 | 06:05 PM
  #26
mildly.interesting's Avatar
**** a screen, run raw like I do!
Old Sep 1, 2005 | 06:56 PM
  #27
2000psi's Avatar
From: We Cant Stop Here This Is Bat Country, So CaL, USDM
Default Re: (mildly.interesting)
a manifold that forces you to not be able to use a proper air filter is not worth using.
Old Sep 1, 2005 | 09:00 PM
  #28
nfn15037's Avatar
Default Re: (2000psi)
I will never get why people don't run ******* air filters.....do you all like sand and pebbles in your compressor or is it the screen blocking off 50% of the inlet area that does it?
Old Sep 1, 2005 | 09:07 PM
  #29
b16hybridsol's Avatar
Default Re: (nfn15037)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nfn15037 &raquo;</TD></TR><TR><TD CLASS="quote">I will never get why people don't run ******* air filters.....do you all like sand and pebbles in your compressor or is it the screen blocking off 50% of the inlet area that does it?</TD></TR></TABLE>
If you'd read the thread and look at pics when people post stuff like this up, you would realize that some setups don't have the space for a filter
personally after running filterless for a while, i'm inthe process of seting up and intake and modifying hella to make one fit
Old Sep 1, 2005 | 09:11 PM
  #30
Haleiwa-Brando's Avatar
Default Re: (b16hybridsol)
Doesn't Greddy or HKS make a full body metal filter that is super short? Why not use that?
Old Sep 1, 2005 | 09:16 PM
  #31
SOHC_MShue's Avatar
Default Re: Turbo Screen Option (Blaze45)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blaze45 &raquo;</TD></TR><TR><TD CLASS="quote">I was running a mesh screen for about 2 weeks. I did a top end pull and sucked the entire thing in and it spat some of it out the exh. when I started it up the next morning. I had it clamped on there pretty tight as well... for DD Im gonna find some sort of filter to put on... But I have 0 room for anything. My compressor housing is touching the radiator and fan shroud. I dont trust screens anymore...
Blaze</TD></TR></TABLE>
Old Sep 1, 2005 | 09:17 PM
  #32
Default Re: (Haleiwa-Brando)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Haleiwa-Brando &raquo;</TD></TR><TR><TD CLASS="quote">Doesn't Greddy or HKS make a full body metal filter that is super short? Why not use that?</TD></TR></TABLE>
the foam style i believe you are talking about. i've seen a car suck the foam in from an hks filter, plus those are really wide and would be even harder to fit in my situation. my fan actually blocks part of the intake
Old Sep 1, 2005 | 09:32 PM
  #33
igy's Avatar
igy
If you do decide to use screen, you want to go buy a tea strainer or a collander that is made out of stiff stainless steel. Porch screen will make a big mess, don't do it.
Old Sep 1, 2005 | 10:50 PM
  #34
yellow blur's Avatar
Default Re: (igy)
I am currently using the HKS Metal Flow filter that I picked up from a SP garage sale a few months back. It's got a 3" opening, and it's very thin. Only downside is that it's very wide. Fit like a glove for my application though, compressor housing facing the driver side in an integra engine bay, no a/c no p/s. I'll post some pictures up soon.
Ed
Old Sep 2, 2005 | 04:06 AM
  #35
sean's Avatar
Default Re: (mrbsponge)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrbsponge &raquo;</TD></TR><TR><TD CLASS="quote">i saw a 16hp gain when i took off my K&N generic filter off while on the dyno</TD></TR></TABLE>
and ran open turbo or did you put a screen on?
Old Sep 2, 2005 | 05:39 AM
  #36
2point2's Avatar
Default Re: Turbo Screen Option (Dturbocivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dturbocivic &raquo;</TD></TR><TR><TD CLASS="quote">filters are alot larger, and have the same style **** going on, but there is so much more area, to allow air to get through.</TD></TR></TABLE>
that is a very good point.
Old Sep 2, 2005 | 05:51 AM
  #37
Bailhatch's Avatar
Default Re: Turbo Screen Option (2point2)
restriction.
Old Sep 2, 2005 | 06:58 AM
  #38
Default Re: Turbo Screen Option (Bailhatch)
if you put a strong screen behind the k&n cloth and made it bubble out a fewinches from the comp housing, you would see minimal power loss
Old Sep 2, 2005 | 10:17 AM
  #39
yee SERIOUS's Avatar
no room in my engine bay maybe if i take out p/s
Old Sep 2, 2005 | 12:20 PM
  #40
hulkhb's Avatar
Default Re: (LiTtOGPiMp)
I am sure I can fit somthing in there for you man.
Old Sep 2, 2005 | 03:26 PM
  #41
http://www.knfilters.com/search/univcone.aspx
Old Sep 4, 2005 | 06:59 AM
  #42
nojoke's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LiTtOGPiMp &raquo;</TD></TR><TR><TD CLASS="quote">http://www.knfilters.com/search/univcone.aspx
Yea, I was hoping they would have a filter that was angled for my setup, but I need at least a 3.5 inch flange opening, and they don't have the filters with that big an opening that are angled...
Old Feb 24, 2006 | 02:52 PM
  #43
RCautoworks's Avatar
Default Re: (nojoke)
I like this setup that Tony did
Old Feb 24, 2006 | 02:57 PM
  #44
andysila's Avatar
nice fab work
Old Feb 24, 2006 | 04:23 PM
  #45
vietjdmboi's Avatar
is that a special pre-formed screen that tony1 is using?if so where can i get one?
Old Feb 24, 2006 | 05:24 PM
  #46
Default Re: (vietjdmboi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vietjdmboi &raquo;</TD></TR><TR><TD CLASS="quote">is that a special pre-formed screen that tony1 is using?if so where can i get one?</TD></TR></TABLE>
I asked him for more info.
Old Feb 24, 2006 | 05:32 PM
  #47
mike93boost's Avatar
you will lose horsepower if you use a screen instead of a air filter and turbo pipe. this has been proven many times right here on honda-tech.
Old Feb 24, 2006 | 05:33 PM
  #48
mexicansi's Avatar
Default Re: (90blackcrx)
i think he said that on another thread, he has to have the car to fab it up. he is an amazing fabricator
Old Feb 24, 2006 | 05:48 PM
  #49
planeman01's Avatar
Default Re: Turbo Screen Option (nojoke)
subscribe so i can purchase later
Old Feb 24, 2006 | 06:02 PM
  #50
Tad's Avatar
Tad
I thought that kn filter wrap stuff was just meant to go around an ACTUAL filter... not function as a filter itself??
if i was stuck in a predicament like this, i'd just use be clever about it.. make a freakin filter to fit if u cant find one.
how hard is it to take a flat filter, cut it to shape, then find some way to fasten it onto ur turbo?
the fastening portion might take some time and thinkin and tinkerin.. but i doubt it's that hard
