Turbo Screen Option
Old Sep 1, 2005 | 08:14 AM
nojoke's Avatar
Default Turbo Screen Option
Well in my search for a filter that could fit my VERY cramped bay(turbo inlet is pointing at the radiator at an extreme angle), I came up emtpy handed. I looked at mesh screens, but the amount of dirt they would let through was unacceptable to me.
So I found this K & N Pre-Charger Filter Wrap. It's part number E-3211PK. So far it works great. I did some highway pulls in boost and immediately pulled over, and found a nice amount of dust and dirt clung to the outside of the wrap. I would consider this wrap over ANY mesh screen, and it was only about $20 shipped from Summit. I mean I can actually see the dust still clung to the filterwrap, dust that would've made it's way to the turbo fins and eventually inside my engine...
The pic is not from when I did the highway pull, just from it was in my driveway...
For the lazy people who don't want to read the review, it's part number E-3211PK and can be found through Summit for around $20shipped. The part number is for the black screen, they actually have blue, red and yellow available as well.
Old Sep 1, 2005 | 08:38 AM
HTDragazn's Avatar
I can only pull up the black one, what is the part number or url to see 3 colors? would like to get some blue stuff to match a little
Old Sep 1, 2005 | 08:50 AM
Adam.C's Avatar
Default Re: Turbo Screen Option (nojoke)
wow thats pretty cool. You think its really picking everything up? good idea though
Old Sep 1, 2005 | 09:13 AM
PM-Performance's Avatar
Default Re: Turbo Screen Option (orangerex04)
im sure it deff picks up more then a screen.
The only thing that scares me on this stuff and screens is seeing dyno vids and watching the screens pulling in while under full load.
That just scares me now that I saw that. lol
Old Sep 1, 2005 | 09:22 AM
khoalie's Avatar
Default Re: Turbo Screen Option (itr206)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr206 &raquo;</TD></TR><TR><TD CLASS="quote">im sure it deff picks up more then a screen.
That just scares me now that I saw that. lol</TD></TR></TABLE>
you could always put a wide mesh behind the screen to prevent this. might flow less, but no pantyhose in your turbo
Old Sep 1, 2005 | 09:24 AM
Default Re: Turbo Screen Option (khoalie)
ive seen wide screens pull in pretty far.
Its scary.
Old Sep 1, 2005 | 09:26 AM
Adam.C's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr206 &raquo;</TD></TR><TR><TD CLASS="quote">ive seen wide screens pull in pretty far.
Its scary. </TD></TR></TABLE>
hmm maybe not such a good idea after all....
Old Sep 1, 2005 | 09:27 AM
EJ1 wilcox's Avatar
If you pull the screen tight and clamp it down really well, then you shouldn't have any problems with the turbo sucking it in under boost.
I think this is an excellent idea.
I wonder if it flows better or worse than an average screen? Did you feel a difference when you switched from a screen to this setup?
Old Sep 1, 2005 | 09:28 AM
Adam.C's Avatar
from the looks of the pic you could prob get a pipe bent down behind the radiator to use a reg filter.
What chassis is this in?
Old Sep 1, 2005 | 09:37 AM
AccidentproWn's Avatar
that seems like a really good idea.
subscribing to this for when i get home.
Old Sep 1, 2005 | 09:41 AM
sean's Avatar
hmm, maybe i should use this with my velocity stack instead.
i just want to know how it flows.
Old Sep 1, 2005 | 09:54 AM
DaveF's Avatar
Default Re: Turbo Screen Option (sean)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sean &raquo;</TD></TR><TR><TD CLASS="quote">hmm, maybe i should use this with my velocity stack instead.
i just want to know how it flows.</TD></TR></TABLE>
it wont flow anywhere near what a regular cone filter would flow.. there is soooooo many less holes for the air to get through.. think about it this way... half of your turbo being blocked off by the screen or whatever it it.. its usually some sort of "cross hatch" type pattern.. the filters are alot larger, and have the same style **** going on, but there is so much more area, to allow air to get through.
Old Sep 1, 2005 | 10:00 AM
nojoke's Avatar
"The K&N PreCharger is a specially designed filter wrap made to extend the service interval of your K&N Filtercharger when used in very dusty conditions. They are made from durable polyester material containing a uniform weave. The PreCharger will stop small dirt particles with minimal restriction to the airflow of the filter. "-K & N Website
That's taken straight from the K & N website. In my opinion, I don't think K & N would make a piggyback of sorts for its filters, if they knew that the flow would be hurt significantly. I would rather run a full filter too, believe me, but space constraints don't allow me to.
The URL is http://knfilters.com/wraps.htm
It's an EG chassis by the way....
Old Sep 1, 2005 | 10:08 AM
DaveF's Avatar
Default Re: (nojoke)
maybe you didnt understand what i was trying to say...
Less area &lt; More area. you have to understand that.
what manifold are you running, that allows your turbo to be so close to the radiator?
Old Sep 1, 2005 | 10:34 AM
john d
Guest
Posts: n/a
Default Re: (Dturbocivic)
when i was getting my car tuned i was wondering what was holding back all the power, then we took the screen off...
with screen- 375whp
w/o screen- 400whp
Old Sep 1, 2005 | 10:37 AM
DaveF's Avatar
Default Re: (john d)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by john d &raquo;</TD></TR><TR><TD CLASS="quote">
with screen- 375whp
w/o screen- 400whp
THANK YOU, my point its proven.
Old Sep 1, 2005 | 10:56 AM
Adam.C's Avatar
wow thats a big *** diff with.without the screen! gotta be a way to fab up a pipe to run a reg filter man
Old Sep 1, 2005 | 11:14 AM
yee SERIOUS's Avatar
i just cut my window screen. hahaha. but that one looks nice
Old Sep 1, 2005 | 12:02 PM
Adam.C's Avatar
Default Re: (LiTtOGPiMp)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LiTtOGPiMp &raquo;</TD></TR><TR><TD CLASS="quote">i just cut my window screen. hahaha. but that one looks nice </TD></TR></TABLE>
omg... You mean like a screen people use for portches? lol, those things have big gaps.
Old Sep 1, 2005 | 12:28 PM
swlabhot's Avatar
with screen- 375whp
w/o screen- 400whp
Why? because a filter has a MUCH larger total surface area than just a screen. A screen only has the total surface area of pretty much just the diameter of the compressor intake, where as if you 'unwrap' a filter cone, you will see just how much total area it actually has. More area = more air flow, hence most of the filters these days are cone shaped and pleated which again increases the surface area a great deal more
Old Sep 1, 2005 | 12:33 PM
john d
Guest
Posts: n/a
Default Re: (swlabhot)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by swlabhot &raquo;</TD></TR><TR><TD CLASS="quote">
ugh... i know...
i have the screen on there when im daily driving here and there, i dont rice around everywhere so i dont need the screen off all the time. when we were tuning i FORGOT to take the screen off. the whole purpose of me posting that information was just to show the restrictiveness of a screen.
Old Sep 1, 2005 | 01:18 PM
no2unenolife's Avatar
that knn wrap looks good, i just wonder if i should use that or my screen
Old Sep 1, 2005 | 05:18 PM
mrbsponge's Avatar
i saw a 16hp gain when i took off my K&N generic filter off while on the dyno
Old Sep 1, 2005 | 05:49 PM
Full-Race Javier's Avatar
another alternative is to use a section of ducting in the tight spot/tight radius areas to a hard pipe and then to a filter.
found some examples on the SDS site...
we used some on a MR2 and it worked well...
Old Sep 1, 2005 | 05:51 PM
Blaze45's Avatar
Brrraaaap!
Default Re: Turbo Screen Option (EJ1 wilcox)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJ1 wilcox &raquo;</TD></TR><TR><TD CLASS="quote">If you pull the screen tight and clamp it down really well, then you shouldn't have any problems with the turbo sucking it in under boost.
I was running a mesh screen for about 2 weeks. I did a top end pull and sucked the entire thing in and it spat some of it out the exh. when I started it up the next morning. I had it clamped on there pretty tight as well... for DD Im gonna find some sort of filter to put on... But I have 0 room for anything. My compressor housing is touching the radiator and fan shroud. I dont trust screens anymore...
Blaze
