turbo rebuild help
Old May 24, 2009 | 04:58 PM
lookout22's Avatar
Default turbo rebuild help
i need help rebuilding my turbo i have the middle bearing section all apart and i cant get the cold side seal plate apart.
(heres an exploded view of it with labeled parts if it helps. http://www.gpopshop.com/garrettt2kits.html) i have the snap ring out but the seal plate wont come. how should i get it out?
please help. Its a jdm garrett t25 from a nissan avenir.
Old May 24, 2009 | 08:20 PM
beyondstock's Avatar
Default Re: turbo rebuild help
I'm lost on what part you cant get out? You removied the ring that holds everything in there right? if so when remove the nut and take the wheel off and the rest is right there..??
are you sending the turbo off the get ballanced?
Old May 25, 2009 | 06:18 AM
lookout22's Avatar
no im not.... should i? what are the benefits. Im pretty new to rebuilding turbos
Old May 25, 2009 | 06:32 AM
shortyz21's Avatar
u have to mark the compressor wheel and shaft befoe u take it apart. or else you have to send it out to have it rebalanced.
something spinning at 50 000 rpm doesnt take well to being unbalanced.
averyvm
Mar 16, 2016 06:10 PM
accord99power
Mar 19, 2011 03:50 PM
Ka chao
Nov 22, 2004 07:45 AM
nigel
Apr 5, 2004 12:46 PM
