Turbo Questions?????
Old Mar 25, 2002 | 09:34 AM
busman's Avatar
Default Turbo Questions?????
#1..What makes the Drag III fail the visual inspection but pass emissions?
#2..Why makes the Greddy Turbo so underpowered?
Old Mar 25, 2002 | 10:43 AM
brian b's Avatar
New User
Default Re: Turbo Questions????? (busman)
#1..drag didn't submit the kit to carb so its not legal in california, and i believe it has an open wastegate
#2..small turbo, it was designed to be a complete bolt on kit designed for almost stock fuel systems
Old Mar 25, 2002 | 11:43 AM
5gen-hybrid's Avatar
New User
Default Re: Turbo Questions????? (brian b)
And the bov vents back into the atmosphere.
Old Mar 25, 2002 | 12:59 PM
ATurboCivic2NV's Avatar
Default Re: Turbo Questions????? (5gen-hybrid)
the bov? how would that be a problem? maybe the valve cover vent!! if this is true i would like to know how.
Old Mar 25, 2002 | 01:09 PM
New User
Default Re: Turbo Questions????? (ATurboCivic2NV)
I don't know because i don't have to go through the visuals but from what i've heard nothing (including bov's) can vent back into the atmosphere.Thats why on stock turbo charged cars they are all routed back to the intake before the turbo.As far as releasing polutants there are non and you will pass emissions just not the visual inspection (if applicable)
Old Mar 25, 2002 | 01:17 PM
well i have heard many times that you can fail visual if you have a valve cover breather.
most stock turbo charged cars come with mass airflow sensors so they have to be routed back and i am sure it is to cut down on the noise also.
Old Mar 26, 2002 | 06:34 PM
BlueShadow's Avatar
-small downpipe, I've heard the Greddy kit for the GSR has a 2" downpipe.
-Greddy's fuel system is only designed for one boost setting (low PSI), you can boost higher PSI but you'll need a custom fuel setup
-with the internal WG you are limited to 15 PSI of "safe" boost
the Greddy turbo's TD05-18G can flow for up to 400-450 HP, you just have to swap out the "bottle-necks" to get that much HP, but if you permenantly change the kit you void the CARB exemption.
[Modified by BlueShadow, 3:35 AM 3/27/2002]
Old Mar 26, 2002 | 08:31 PM
NeXtLeVeL_TyPe_R's Avatar
Default Re: Turbo Questions????? (BlueShadow)
wow failing inspections because of a visual test
That Sucks
Never heard of anything like that around here.
But thats NYC, i dont pash emissions either but i know joey from the bagel store down the block and he told me if i slip the guy twenty i can pass
Gotta love NY !!
alacard
Jan 8, 2006 08:52 AM
slowater427
Oct 18, 2005 09:54 PM
WreckedTeggie
Feb 12, 2004 01:16 PM
95 civic
Sep 5, 2003 02:03 PM
ragejed
Jun 1, 2002 05:15 AM
