Turbo question (Noob in the room)
Other than the turbo kit, and engine modifications, for example, re-sleeving, port and polish and milling, injectors, valves and springs and retainers, axles and tranny on the car. What other items are included in a bomb *** turbo setup?
For example.
Do I need a new or chipped ECU, a new fuel pessure regulator, if so what kind? Do I need something to keep my oil cool or any other electronics other then the boost control? what Kind?
Trying to educate my self about all the part needed for a good setup. This would probably help all the other noobs too.
Thanks
For example.
Thanks
I live under a rock
Re: Turbo question (monsterb18b)
WTF is a bomb ***?? I hope you aren't saying bomb as in da' bomb, because that would be really..... really, pathetic.......
USE SEARCH........ YOUR ANSWER IS WAITING
Re: Turbo question (drvfast)
tsss I would say don't even need the search button, just read on the board, section forced induction and on the first page you'll have a lot more answer that we may post on this topic
dude your funny,, LOL
-search about hondata... best bang for the buck as in ECU tunning
-FPR ... its up to you , b&M, Aeromotive, paxton, AEM ect
-no your oil will be fine.
-meter and gis~mo's you'll find helpful...boost controler, boost meter, oil temp meter, oil pressure meter, water temp, air fuel ratio meter, EGT (exhust gas temp) meter.
much more info you need to learn and you have along way to go. BTW when you post do more reaseach and try to sound professional in a way so that people will take you seriousely. HTH
Re: Turbo question (Charlie Moua)
Thank for the reply. At least you are sincere.
I know I need to read more posts. Just wanted a run down on all the common setups for turbo So I can study and find out what each part or upgrade will do for the motor in terms or whp and torque.
If you guys didn't notice i am a noob at force induction setup.
Any technical information would be appreciated.
