Turbo question
Old Apr 13, 2011 | 07:40 PM
GoSickemRobert's Avatar
Default Turbo question
I got a brand new AiResearch/Garrett '5031' turbo .48 turbine housing .60 compressor housing. I was seeing what the max hp I can get with good efficiency. I think the 5031 is 50mm exhaust 31mm intake?
Old Apr 14, 2011 | 08:37 AM
TheShodan's Avatar
Moderator
Default Re: Turbo question
you're confusing the Garrett with the Precision line. the 5031 is a Precision designation is equivalent to the Garrett AiResearch 50 "trim" that uses a T31 turbine housing ("31") and a 50 trim 58mm inducer. Your maximum hp on that particular turbo is about 420whp. it starts to get inefficient for Honda B-series VTEC engines at about 19-23psi of boost pressure. Inlet of the turbo is more than likely about 2.5", while the compressor outlet is 2" to the intercooler. Turbine inlet is more than likely T3, while the outlet is a 2.5" T31 turbine 4 bolt. But they do come in Ford Style SVO 5 bolt turbine housings as well.
Old Apr 18, 2011 | 02:42 PM
Awesome thanks for the info. There was no badge just the turbine housing said AiResearch and i knew the info on the wheels. Ill be on 17psi on my gsr with a built bottom. Getting her tuned friday
Xathine
Dec 30, 2008 12:56 PM
og_hatch_90
Jan 12, 2006 01:24 PM
yangtech
Oct 24, 2004 10:27 AM
InfamousRS
Dec 16, 2001 01:47 AM
