turbo question
Old Jan 30, 2007 | 03:29 PM
honintegra's Avatar
Default turbo question
ok i have a garrett t3 turbo and i was running it on my car for about 2 days then it started smoking really bad i had the feed on bottom and the return on top so i pulled it all off and took the turbo apart the rings look ok and the bearings look good so cleaned it all up and put it back together with the feed on top and return on bottom do you think it will work b/c i dont want to pull off my other turbo and waste my time if it is going to smoke
Old Jan 30, 2007 | 03:47 PM
TypeSLO's Avatar
Default Re: turbo question (honintegra)
if it's smoking now, most likely it'll smoke again. why did you hook up your oil lines that way in the first place? you may need to rebuild it.
Old Jan 30, 2007 | 04:48 PM
honintegra's Avatar
i couldnt get it to clock i tried a bunch of times finnally i just beat the crap out of it and it came apart
G-Auto*Hero
Jun 4, 2009 07:26 PM
SlowSOHC-T
Oct 26, 2007 04:09 AM
Mr. LS VTEC
Sep 17, 2006 10:51 AM
Mr. LS VTEC
Sep 16, 2006 05:39 PM
slo_crx
Mar 30, 2005 04:26 PM
