turbo question
Old Jan 22, 2006 | 03:28 PM
zccr-xsi's Avatar
Default turbo question
i got a DOHC zc motor and i will be boosting it very soon.what i want to know is what will be good size turbo to put on the zc?and how much boost can i push safly on stock bottom end?i was thinking round 8 9 pounds the most.if anyone has boosted a zc safely please relpy and give me some advice.
Old Jan 22, 2006 | 05:09 PM
urbansi's Avatar
Default Re: turbo question (vteckillenzc)
Decide your power goals, then pick a turbo and see if it gets you were you want, forget psi, aim for hp first then decide, JMO
Old Jan 23, 2006 | 05:37 PM
zccr-xsi's Avatar
well i got stock botten end right now.im thinking for turbo ill be useing t/3 from the gst.hp goals im looking to reach 185 to the wheels.is it better the buy one of them oil sandwiches to go in the back of the block?or should i tap the pan?seems easyer to put the sandwich on there then i got extra oil port for oil presure guage.btw i want to keep it to where i can still drive it daily.
Old Jan 23, 2006 | 05:39 PM
highmilehatch's Avatar
Default Re: (vteckillenzc)
How much boost you can run depends on turbo selection and what you tune it with. 185whp shouldn't be too much of a problem.
Old Jan 23, 2006 | 06:19 PM
grnhatch94's Avatar
Default Re: (highmilehatch)
id go with t3/t61. no just playing you should reach 185 to the wheels at 7-8lbs of boost with a t3.
Old Jan 24, 2006 | 03:51 PM
zccr-xsi's Avatar
what im going to do is get everything together.but before i put it on i want to change **** like oil pan gasket,intake gasket head gaseket,things like that.anyone suggest a good sounding bov?
Old Jan 24, 2006 | 05:40 PM
urbansi's Avatar
tial
djkina
Jan 15, 2015 12:07 PM
90crxsi88zc
Sep 12, 2005 11:10 AM
cutmaster
10
Jan 31, 2005 06:05 AM
ak91crxHF
Jun 16, 2003 08:35 PM
JV
Jan 23, 2002 01:23 PM
