TURBO QUESTION
im tryin to build my b18c1 motor...i wanted to stay all motor i just want some
more power....heres my set up
I/h/e,skunk im,p28 chipped,vfac,skunk 2 stage 2,head is ported, valve springs,retainers, 5 angle valve job, pretty much my comp..is stock..my question is will i be safe to boost my motor with this set up with my stock gsr cams....??? this is my daily car...so i want it to be as reliable....
yes it will be fine. Compression has not too much to do with it. Higher compression just leaves less room for error on the tuning. I'm at like 10:6:1 boosting 15psi all day long.
Please read and research before you post questions like this that have been covered so, so many times. Broaden your search, make it less specific, check in archived posts are things you can do if you do not find what your looking for.
