Turbo Problems for Prelude??
Old Dec 17, 2001 | 08:04 PM
SiREF8's Avatar
Default Turbo Problems for Prelude??
Well I have problems w/boost leaking out, the kit I have is the Turbonetics kit and I hear boost just leaking out. Please any info will help out w/this problem. I think that the problem is the wastegate, but I may be wrong so help w/this problem. <U></U> http://www.intercrewautosalon.com
Old Dec 18, 2001 | 08:42 AM
Blownlude's Avatar
New User
Default Obviously, you have to locate your leak.
If it's as loud as you say, you should be able to feel an exhaust leak with your hand if it's coming out of your wastegate. Double-check all your vacuum lines. Could be one of them popped off. Most likely, if you can't boost much it's an exhaust leak.
Old Dec 18, 2001 | 10:07 AM
SiREF8's Avatar
Default Re: Obviously, you have to locate your leak. (Blownlude)
Well we've checked every pipe and every vacuum hose, etc. but no leaks found. I'm going to replace the wastegate this week so we'll find out if that was it, but I'll double check everything on the kit to make sure, thanks for the info thou. <U></U> http://www.intercrewautosalon.com
Old Dec 18, 2001 | 02:38 PM
greengangsta's Avatar
Default Re: Turbo Problems for Prelude?? (SiREF8)
it is the wastegate. if it is a turbonetics wastegate then that is the problem. my friend has one on his car and he hasn't even driven 1000 miles yet and it is already leaking. he is gonna replace it with the hks one that is good up to 450 hp.
Old Dec 18, 2001 | 02:39 PM
Tomakit's Avatar
Default Re: Obviously, you have to locate your leak. (SiREF8)
Can you be more specific?
What kit are you running?
How many lbs is the wg set for, and what does your boost gauge read?
Open or closed loop wg?
Tom
Old Dec 18, 2001 | 08:16 PM
SiREF8's Avatar
Default Re: Obviously, you have to locate your leak. (Tomakit)
Well we thought the same b/c personally Turbonetics makes the worst wastegate out on the market. So already going to order another and see if it works, thanks for the help. <U></U> http://www.intercrewautosalon.com
Old Dec 18, 2001 | 10:37 PM
Arturbo's Avatar
Better than steak
25 Year Member
Do you work at intercrew or something because its in all your post.
Old Dec 18, 2001 | 10:42 PM
SiREF8's Avatar
Default Re: Obviously, you have to locate your leak. (Arturbo)
Nope, do it for phillip he's a real good friend of mine. He does alot of work on my car. Just thought I'd give him props for his work, so he knows he don't care. Why you want to know??? <U></U> http://www.intercrewautosalon.com
Old Dec 18, 2001 | 10:43 PM
Arturbo's Avatar
Better than steak
25 Year Member
Well because they installed the turbo on Teej's car.
art
808draggers
Jun 24, 2007 04:13 PM
krazyhmongboi
Jul 6, 2006 08:22 AM
si foo
Sep 28, 2003 05:21 PM
KLN
Jul 1, 2002 01:58 AM
SiREF8
Dec 18, 2001 05:01 AM
