turbo problems.
Old Jul 13, 2004 | 09:32 PM
khmboostedeh2's Avatar
Default turbo problems.
alright guys im having some problems with my turbo, and i have no idea what it is.
b18b1, 1993 civic dx.
alright heres the symptons, the turbo winds up and it'll pull hard, then stop. unless i let off the gas and hit it once again. every now and then, it sounds like pressure is escaping somehow. the BOV also goes off if i release the gas pedal the slightest bit.
i dont have a missing link just yet, just check valves. and the check engine light comes on frequently.
im assuming that the fuel pump cant handle it? and then the engine bogs when the CEl comes on.
Old Jul 13, 2004 | 11:59 PM
boostedlude3g's Avatar
Default Re: turbo problems. (Jeterkm02)
whats the code?
Old Jul 14, 2004 | 03:40 AM
Chillinit's Avatar
I think you need some proper tunning. When my ride wasn't tuned properly, I had similiar symptoms where @ WOT it will pull hard till about 5000 rpm then fall flat on its face. I would let off a little then get back on it in order for the power to return. I was running mad rich on the top end.
Old Jul 14, 2004 | 07:35 AM
Default Re: turbo problems. (Chillinit)
yeah whats what im assuming, what did you end up doing to tune it?
as for the CEL, do i have to check the code bein thrown off while the CEL is still on? as soon as the car is turned off, the CEL turns off.
Old Jul 14, 2004 | 01:46 PM
anyone?
clean99si
Engine Management and Tuning
Feb 19, 2011 09:28 AM
drp123
Sep 27, 2008 06:39 PM
drkns
Jul 21, 2006 09:11 PM
34psi
Jun 26, 2004 07:40 PM
cdog19
Feb 23, 2004 05:25 PM
