Turbo prep
Old Sep 1, 2007 | 12:35 AM
1BADEGDC2's Avatar
Default Going Turbo ... Got ?s
hey guys, i wanna go turbo on my usdm type r. Ive been all motor and this is gonna be the second forced induction set up, after i plug in the nitrous i want to know what i have to do to the engine to make it safe, dont wanna go KABOOM! im lookin to boost 15-25lbs. My engine has stock internals. Also any brands that you guys recommend i would appreciate it. Thanks for all the help!
Old Sep 1, 2007 | 10:49 AM
OLD_HATCH's Avatar
I would defintely suggest opening up that block and getting some lower cmp pistons and rods. after that engine management.
I thought the type R's had like an 11 to1 comp ratio. If so you might not be able to go past 7-8psi on the stock block without blowing your ringlands and possibly ruining your head with piston parts.
Old Sep 1, 2007 | 01:21 PM
doood's Avatar
been there done that
Default Re: (OLD_HATCH)
you can boost as is. but if you want to be safer lower the compression.
Old Sep 1, 2007 | 01:24 PM
1BADEGDC2's Avatar
like i said i dont want my **** to blow. so i need pistons and rods for the block, what about the head?
Old Sep 1, 2007 | 01:27 PM
doood's Avatar
Default Re: Going Turbo ... Got ?s (1BADEGDC2)
the head is fine as is
Old Sep 1, 2007 | 01:31 PM
posHonda's Avatar
15-25lbs of boost?? thats very broad. if its on any medium to large sized turbo than youre going to have to drop the compression. build the block and you can leave the head as it is.
Old Sep 1, 2007 | 01:47 PM
jfruauff's Avatar
Default Re: (iVteC_PoWeR)
you need to read,lol.
Also pick a hp range not a boost range. Then we can help match turbo and boost to the power your looking to get..
Old Sep 1, 2007 | 05:23 PM
thekid03's Avatar
Default Re: (jfruauff)
I prepped my typeR for turbo few months back
eagle rods
wiseco pistons
balanced crank
3-way valve job
ACT clutch
I proceeded to stall my car twice on the way home trying to get used to that clutch
Old Sep 2, 2007 | 08:40 AM
Sr420Det's Avatar
Yeah but 8 pds on a type r will be stupid fast.
Old Sep 3, 2007 | 08:26 AM
1BADEGDC2's Avatar
Default Re: (thekid03)
about how much did you pay? hows the car runnin now <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thekid03 &raquo;</TD></TR><TR><TD CLASS="quote">I prepped my typeR for turbo few months back
eagle rods
wiseco pistons
balanced crank
3-way valve job
ACT clutch
I proceeded to stall my car twice on the way home trying to get used to that clutch </TD></TR></TABLE>
Old Sep 3, 2007 | 08:55 PM
LVTypeR_EG6's Avatar
hey guys, i posted this on my friends screen name, but i decided to join... well i got a new set up, its a b16 block with 1 bad piston(plan to change all since im goin turbo) gsr head, and a ls tranny, everything only ran me 450 so id rather build this up. so looks like im gonna need low comp. pistons, rods. whats balancing the crank? and 3 way valve job?
Old Sep 9, 2007 | 08:19 AM
thekid03's Avatar
Default Re: (1BADEGDC2)
about 5k.....i didn't have a car for about 2 weeks....machine work to lower compression took the most time. I had them take pics + a few pics from last road trip
Modified by thekid03 at 10:02 AM 9/9/2007
Modified by thekid03 at 1:31 AM 10/19/2007
newtothescene
Apr 5, 2008 04:53 PM
tjohnson329
Dec 16, 2004 09:06 PM
JdM_Eg_6
Jun 7, 2004 07:57 AM
Rah Rah
Aug 11, 2001 12:22 AM
