Turbo prelude problem
hey im having a problem with my car
i have a 01 honda prelude boosted here some info on it
upgraded turbo in a Precision SC6031, still a .63AR, but upgraded to a 60 trim. A Benson sleeved block: hot tanked, squared and surfaced, Benson Machine sleeves installed with a .003" stepped deck, Benson bored and honed cylinders, Benson balanced and micropolished crank, CP 9:1 pistons and rings, Manley rods, some other goodies.
im useing a p78 gsr ecu with crome on it
the guy i got my car from had precision 880cc injectors low impedance he had a Resistor Box wired in
i changed them out for 750cc RR injectors
\DO I STILL NEED A RESISTOR BOX FOR THE NEW INJECTORS???
the are idels like **** like about to die then jumps back up any ideas ive checked eveything else over in the car
i had got the car with these problems so i chaged eveything cap roter plugs wires
and new injectors from 880cc to 750cc rc's
now should i take out the HONDATA 3B AND PUT IN CROME ????
Do what the guy above you said, go get it tuned for those injectors. As far as the resistor box, I have no idea. As for S300 and Crome, I'd use whatever your TUNER is more comfortable with.
i ran Rc 1000cc's on my H23VTEC with Crome idle steady at 1000rpm, no problem 400whp daily driven, just get it tuned and u should be fine...
