Turbo prelude help?
Old Feb 8, 2005 | 10:27 AM
TurboBlueLude's Avatar
Default Turbo prelude help?
ok, so this is my first turbo honda the things i have are:
T3-super60 turbo
turbonetic 35mm wastegate
greddy BOV
Grredy FMIC
MSD 6BTM
VAFCII
450cc inj.
AEM fuel rail
255LPH pump
MAP check valve
Now before the MAP check valve it would cut out at vtec, the boost would drop to from 6psi to nothing, haven't been on dyno since what else should i do? I have a set of skunk2 stage 1 cams and cam gears, should i even bother installing them since they are not turbo cams or will it still give me more power? any help is good help. thanks, Dave
you can check it out at http://www.cardomain.com/id/turbobluelude
Old Feb 8, 2005 | 10:29 AM
tgreaves's Avatar
Default Re: Turbo prelude help? (TurboBlueLude)
What are you using for fuel management? If you have a check valve on there I assume that your not running a afc hack..
Old Feb 8, 2005 | 10:31 AM
Default Re: Turbo prelude help? (tgreaves)
I have the VAFC2
Old Feb 8, 2005 | 10:36 AM
the apexi vtec air flow converter, i know its not the best thing to use but i already had it.
Old Feb 8, 2005 | 10:38 AM
tgreaves's Avatar
Well thats not good using the vafc with the check valve, the afc then doesnt know that your in boost..
Old Feb 8, 2005 | 10:39 AM
I haven't run it with the check valve on it yet. then why would it cut out when vtec hits?
Old Feb 8, 2005 | 10:41 AM
mplays's Avatar
Put money into a Hondata and tuning, well woth the money and will run much safer. You got eveything else you need looks like
Old Feb 8, 2005 | 11:40 AM
tgreaves's Avatar
Default Re: Turbo prelude help? (mplays)
Im kinda biased against hondata so I wouldnt recommend that to anyone.. If you looking for something cheap and easy why not check out uberdata..
As for the vtec cutting off I have no idea there, I would say either your leaning out really badly there or something.. Try turning the vtec off on the vafc controller and see if it still does it.. Maybe you dont have something wired correctly with the vafc controller..
Old Feb 8, 2005 | 11:55 AM
The vafc2 is wired right and its not the vtech that shuts off, its like the whole car shuts down power drops to nothing boost drop, plenty of fuel. whats the uberdata web site and what system would you recamend?
Old Feb 8, 2005 | 12:03 PM
tgreaves's Avatar
Well you would have to convert to obd1 and run an ecu that it supports.. Their site is uberdata.org..
Old Feb 8, 2005 | 02:43 PM
BB6-213's Avatar
Uberdata!
Old Feb 9, 2005 | 06:37 AM
PrecisionH23a's Avatar
My guess is you are not running the proper spark plugs along with the gap.
Try the ngk 3330's gapped to a .028
It's that or you have a vacuum leak somewhere. I'm not a fan of uberdata to be honest. To each his own. Either way you can sell your afc2 and btm and easily get the hondata for right around the price you sell them for.
hatchedzex
Jul 18, 2004 05:47 PM
blackssvtex
Aug 12, 2003 12:21 PM
NOSED_CRX_VTEC
Oct 18, 2002 06:07 AM
Immortal23
Dec 5, 2001 01:53 PM
