turbo oil drain fitting question
Old May 2, 2007 | 05:54 PM
labtec's Avatar
Default turbo oil drain fitting question
im piecing together a few fittings for my turbo drain and i needed feedback on some things
http://www.anplumbing.com/shop...!_Ons
the male an weld fitting -10
would weld into the oil pan
and connect to
http://www.anplumbing.com/shop...-Seal
the 45 degree swivel seal forged end -10
and that would connect to a -10 hose that drains from the turbo
(stealthmode kit)
that setup would work right? im like 100% sure it would. i have jb weld on right now but i want a real solution. thank sfor your time
Old May 2, 2007 | 06:55 PM
black98gsr-t's Avatar
Default Re: turbo oil drain fitting question (labtec)
as long as the fitting being welded to the oil pan is the same (steel pan - steel as fitting)( alum. an fitting - alum. pan).. looks good
Old May 2, 2007 | 07:39 PM
inspyral's Avatar
You could also use a union/bulkhead fitting and stat-o-seal washers for a weldless leakfree drain fitting like this:
Old May 3, 2007 | 08:07 AM
ProJectCvic's Avatar
Default Re: (inspyral)
that would be nice for someone that doesn't have a welder. I would get the steel one and weld it on to make sure no leakage.
Old May 3, 2007 | 08:47 AM
jmm96gsr's Avatar
Default Re: (ProJectCvic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ProJectCvic &raquo;</TD></TR><TR><TD CLASS="quote">that would be nice for someone that doesn't have a welder. I would get the steel one and weld it on to make sure no leakage.</TD></TR></TABLE>I had mine welded on, it's nice that I work for a company that has 6 guys welding everyday.
Old May 3, 2007 | 10:53 AM
Snafubmx234's Avatar
Since when was JB Weld not a real solution
justYncredible
Feb 8, 2012 10:20 AM
MalcolmV8
Dec 5, 2011 05:29 PM
Turbo-GSR1287
Jun 23, 2008 08:15 PM
labtec
May 2, 2007 06:08 PM
RedStarGsr
Dec 25, 2003 10:21 PM
