Turbo obd1 conversion
Old Nov 25, 2007 | 02:04 PM
roachsboosted16's Avatar
Default Turbo obd1 conversion
i have a d16y7 turbo with a obd2a ecu, and im switchin it to obd1, what else do i need to do besides tweak the iacv, and get a conversion harness for the ecu?
Old Nov 25, 2007 | 02:12 PM
Schister66's Avatar
Man U FTW
You shouldnt have to touch the IACV...i dont recall ever having to mess with mine. All you need is a conversion harness and the new ECU
Old Nov 25, 2007 | 02:13 PM
Default Re: Turbo obd1 conversion (roachsboosted16)
my car is idling like a heartbeat.... i need to convert mine from a 3 wire iacv to a 2 wire iacv so the obd1 ecu can recognize it.
Old Nov 25, 2007 | 02:33 PM
boostedcivicsir's Avatar
Mr. Badwrench
i dont know of an easy way to wire the 3 wire iacv, BUT if you do a y8 manifold conversion, you can use the iacv on the on the y8 mani (which is a 2 wire)
plus youll benefit from the y8 mani over the y7.
someone else chime in if you can interchange the y7 iacv with the y8 (manual iacv ) as a y8 auto is a 3 wire also.
Old Nov 25, 2007 | 05:57 PM
confucioussae's Avatar
Default Re: Turbo obd1 conversion (boostedcivicsir)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedcivicsir &raquo;</TD></TR><TR><TD CLASS="quote">i dont know of an easy way to wire the 3 wire iacv, BUT if you do a y8 manifold conversion, you can use the iacv on the on the y8 mani (which is a 2 wire)
someone else chime in if you can interchange the y7 iacv with the y8 (manual iacv ) as a y8 auto is a 3 wire also.</TD></TR></TABLE>
Y7 and Y8 Auto are interchangable, 3 wire IACVs
Y8 manual has the 2 wire, this is what you'll need to go obd1.
https://honda-tech.com/zerothread?id=1055268&page=1
jonathan13
Dec 8, 2007 05:03 PM
combz
Jul 15, 2007 02:59 PM
dank24
26
May 31, 2006 06:10 PM
Mr. 1582
Oct 15, 2003 06:18 AM
