turbo not spinning
Old Feb 26, 2008 | 08:37 PM
JDM_95_LS's Avatar
Default turbo not spinning
i rebuilt the turbo today and now it's not spinning when i sprayed air in there. what could be the problem?
Old Feb 26, 2008 | 09:39 PM
MiraiZ's Avatar
Default Re: turbo not spinning (JDM_95_LS)
Did you put any oil in it?
Old Feb 26, 2008 | 09:42 PM
Schister66's Avatar
Man U FTW
Depending on the amount of assembly lube in the turbo, it may be a little tight and hard to turn. Once there is fresh oil running through the turbo, it should become easier to spin it. If the rebuild was done correctly, i wouldn't worry about it. My first turbo (60 trim) didnt spin at idle for the first 3-4 minutes after initial startup. Once it had oil run through it for a short while, it started spinning just fine.
Old Feb 26, 2008 | 10:31 PM
manoy's Avatar
Default Re: (Schister66)
when you turn the compressor wheel do you feel something or is it smooth .. i dont want to sound rude or something but rebuilding a turbo is not just assmbling it .. try to dissasemble the comp housing ang try spraying air on it again .. it must be well lubricated (shafts) .. yes normally in a bushing type of turbo at first .that happens .(impeler not moving on idle). there is a break in also i a new rebuilt ..
Old Feb 27, 2008 | 07:01 AM
JDM_95_LS's Avatar
Default Re: (manoy)
yeah when i spinned it with my finger it was spinning pretty smooth
Old Feb 27, 2008 | 07:25 AM
da_dude's Avatar
I wouldn't worry about it. It'll just take time for the oil to lube the turbo.
Old Feb 27, 2008 | 08:36 AM
manoy's Avatar
Default Re: (da_dude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by da_dude &raquo;</TD></TR><TR><TD CLASS="quote">I wouldn't worry about it. It'll just take time for the oil to lube the turbo.</TD></TR></TABLE>
Old Feb 27, 2008 | 09:21 AM
JDM_95_LS's Avatar
Default Re: (manoy)
so everything should be fine?
Old Feb 27, 2008 | 11:54 AM
TheShodan's Avatar
Moderator
Default Re: (JDM_95_LS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_95_LS &raquo;</TD></TR><TR><TD CLASS="quote">yeah when i spinned it with my finger it was spinning pretty smooth</TD></TR></TABLE>
Old Feb 27, 2008 | 11:56 AM
TheShodan's Avatar
Moderator
you're fine.
turboman2.2
Apr 30, 2010 07:05 AM
teg_95
Jun 5, 2009 08:33 PM
nihad
Nov 30, 2008 06:40 PM
blackcrx16
Jul 30, 2007 06:11 AM
nortel
Feb 11, 2003 12:33 PM
