grr detonation is pissin me off
well i got my car tuned back in the day and i still hurd detonation. heres the setup
H23 t3/t4b turbo @8psi
cams
Intake
LIFT -
0.420
DURATION -
258
Exhaust
LIFT -
0.421
DURATION -
258
Hondata s200bd
timing 16 degrees
fuel pressure 39 (idle)
Walburo 255 high pressure
-6AN fuel lines
AEM rail
aeromotive FPR
550 RC injectors
crane ignition
msd coil
shitty *** rev hard pos gay ****** retarted piece of mother bitch manifold that my sister could make better.
3" turbo back
Air fuel
3k rpm- 13.5
4k rpm and up-11.0(playin safe)
so why the hell do i hear mad detonation.... is it the cams?
cams
Intake
LIFT -
0.420
DURATION -
258
Exhaust
LIFT -
0.421
DURATION -
258
Hondata s200bd
timing 16 degrees
-6AN fuel lines
AEM rail
aeromotive FPR
550 RC injectors
crane ignition
msd coil
3" turbo back
Air fuel
3k rpm- 13.5
Re: grr detonation is pissin me off (BoostedH23a1)
are you sure its detonation? perhaps another issue?
Put in some high octane and see if the noise goes away. If it doesent, then you have a different problem, if it does, then you need to re-tune it, or make sure your base timing is on.
Re: grr detonation is pissin me off (lazerus)
it sounds like detonation the damn pinging and ****.. its not like loud ping.. but it sounds like theres a bb in my cylinder or someting which detonation sounds like.. what kidna octane level?100?110?
street dreams
11-14-2003 08:30 PM
