turbo manifold paint
is there any paint out there that someone has used w/ success in painting the turbo manifold? i know they make 1400 degree paint. but will that withstand the heat of the manifold?
ah i knew it
i cant decide if i shoud jet-coat everything
or wrap it
or paint it with the 1500 degree paint
i spent a grip of $ on my setup
i dont care about bling bling
but max rev manifolds look nasty (all brown and rusty looking )
i want my setup to look clean
or wrap it
Hatchblack showed me this site...
http://www.performancecoatings.com/benefitdata.htm
Look at some of the pictures. If you don't like the bling look they also have a few other finishes that withstand 2,000 degrees F.
i went to home depot and bought high temp paint for like bbq grills, holds till about 1500, hasnt flaked, looks great. since my manifold is cats, i just wire brushed and sanded the excess rust dust, dryed it, then heated it a bit under a lamp, sprayed it a few times, and let it dry. worked great and the paint is intact. try that before a hundred $+ ceramic or that other crap
Mensuro
Jun 3, 2011 07:19 PM
BobGnarly
May 31, 2004 10:10 AM
