Turbo Manifold
What you guy's think about this Manifold?????
I would like to put this on my B16a2 motor with a T3T4 turbo .53a/r .63 a/r, would this work without me having to cut or shave my block for the turbo???????
Any info pleasethank you....
my BLOX is very similar.. i had to shave the block for A/C setup.. otherwise it would clear if you mount the compressor on the driver side
it works fine unless you're shooting for big numbers
yea I have a Blox Manifold to and we had to notch my engine a bit I also made a bend tube off the manifold to mount the waste gate out of the way I just removed my ac I didnt use it any ways but have plenty of room now.
i had that exact same manifold, yes you need to shave the block, shaving between runners 2 and 3 will also help with the dipstick
its a great manifold, never had any creep problems and made great power with it
Looks live a good copy of the inlinepro cast. Is your turbo a 4 or 5 bolt. This is important as a 4 bolt turbo will not fit with this manifold. I just got done dealing with that exact problem. Thanks to Blastperformance I got a 5 .63 Stage III turbine housing on the way! Good luck!
Where are you refering too?????
If you referring to the 4 bolt on the turbo flange to the 4 bolt flange on the manifold, then yes I have a 4 bolt to bolt on the manifold, but if you mean the exhaust side of it also, yes I have the turbo with the 4 bolt where the downpipe bolt onto the turbo is 4 bolt.
Overall both the turbo flange to the manifold and the downpipe bolt on flange to the rear of the turbo I have 4 bolt.....
BOOSTEDgs-R
Feb 18, 2008 09:47 PM
