Turbo Maint.
Old Aug 3, 2002 | 12:05 AM
Cyrio's Avatar
Default Turbo Maint.
What do you guys do on a daily/weekly/monthly basis to make sure everything with your turbo car is in order? What should i watch out for and what should I avoid?
Old Aug 3, 2002 | 01:16 AM
B18-T's Avatar
Default Re: Turbo Maint. (Cyrio)
I'm pretty new to the turbo world, but I check for ??shaft play??(dont know if thats what its called, but I know what I mean, which is enough), oil leaks, and look to see tht everything is tight and secure. Is there anything else I should look at??
Old Aug 3, 2002 | 01:45 AM
rjardy's Avatar
Default Re: Turbo Maint. (B18-T)
plugs, change them with every oil change....why not there cheap. and just make sure that you are not detonating.
Rob
Old Aug 3, 2002 | 01:59 AM
Tofurky's Avatar
about every other day i pop the hood check vacuum lines, fuel lines, make sure i'm not missing bolts
check oil, coolant. at least 91 octane(stupid california).. blablabla
i'm sort of over careful now, after my first run in with fried pistons (after 2 months )
while driving, always be listening to your car... and under WOT listen very carefully...
detonation, exhaust leaks, and unusual noises...
don't pull the "maybe if i floor it, it will go away" approach
just be careful on way hot days, especially in traffic
and practice common sense!
Old Aug 3, 2002 | 02:03 AM
rjardy's Avatar
Default Re: Turbo Maint. (Ruckus138)
uhhh huh!!
Rob
Old Aug 3, 2002 | 11:24 AM
RuthlessEF-9's Avatar
Default Re: Turbo Maint. (rjardy)
have a costco size stash of oil
you'll need it
hell stock up on everything
make your pep boys in your own garage
Old Aug 3, 2002 | 02:47 PM
Brian_92GSR's Avatar
New User
Default Re: Turbo Maint. (ruthlessSpecR)
Definately lots of oil. My last trip to wal-mart I bought every 5 quart container of super tech 10w-30 they had. Walked out with about $85 worth of oil, and at $4.17 per 5 quart jug that is quite a bit.
Old Aug 3, 2002 | 02:52 PM
FredoSP's Avatar
yupp sounds good, and remember if something does go wrong the cheap way will always get you in the end!! So spend the $ now and dont have a huge headache in the end.
Old Aug 3, 2002 | 03:36 PM
PrecisionH23a's Avatar
You can do what you choose, but this is what i usually do...
Change oil every 2k-2500 miles
Check oil level every other day or so
Check for any leaking fluids/oil or loose vacuum lines every every so often
Check spark plugs every weekend
and of course the things everyone else mentioned.
93 Eg Couper
May 2, 2011 02:21 PM
sleevedgsr
Nov 29, 2004 09:05 AM
fast94ex
Sep 29, 2004 11:15 AM
S2KP
Dec 25, 2003 10:52 AM
OKSolSi
May 16, 2002 08:52 PM
