turbo ls teg
Old Apr 25, 2003 | 10:46 AM
dohc-nyne's Avatar
Default turbo ls teg
anyone with ls integras....whats nessicery as far as fuel upgrades required to run 7 psi....???? thanks
Old Apr 25, 2003 | 12:59 PM
Teg4e's Avatar
Default Re: turbo ls teg (dohc-nyne)
something like zip's smc or an apex'i safc with some dsm injectors is a good, cheap fuel setup. take it to the dyno to make sure you're around a 12.0:1 air/fuel ratio. Stock ignition timing should be safe for that boost level.
Old Apr 25, 2003 | 01:02 PM
EG6owner-T's Avatar
Default Re: turbo ls teg (Teg4e)
what if you want to put some 440 cc with an air/fuel controller with the fmu?
skunkedteg108
May 10, 2006 04:05 PM
Drifterz32
Mar 7, 2005 07:01 PM
Bictorious
Feb 15, 2004 06:26 PM
EF8SIR
Apr 27, 2002 07:18 AM
k5
Mar 22, 2002 12:39 AM
