Turbo Kit w/NOS????
yea i'm thinking about turbo charging a h22 or b18c1 motor......and i need to know what kind of turbo kit would be safe to run a a direct port nitrous kit or what's a good turbo kit to have with nos.....and what else do i need done to the engine????????
you are definitely gonna need to get forged pistons and rods, and depending on your boost level goals, dropping your compression might be necessary. if you plan on using the nitrous as a low end enhanceruntil the boost comes in, then i don't think there should be too much of a problem with cylinder pressure getting too high(again, this depends on your boost level). if the nitrous is to be a top end additive, then lowering your compression is a must. some more information on your intentions, price cap, and driving habits would be hepful if you need more information.
it's just gonna be a Daily driven car....and Nos for the track......i just want low 8's or 7's in the 1/8th........and it's a 5 speed.....i also looked up this Nos programmable controller is that any good? ALSO HOW WOULD I GO ABOUT LOWERING MY COMPRESSION????
[Modified by New2HD, 5:29 PM 1/3/2002]
Turbolude
Dec 14, 2001 07:10 AM
