drag kit fuel system
Old Jun 4, 2002 | 03:18 PM
Mr. Softee's Avatar
Default drag kit fuel system
is the fuel system that comes with the drag kit for an LS good enough to see 9 or 10 psi? (if tuned) on B series injectors.
sam
Old Jun 4, 2002 | 03:49 PM
dustin's Avatar
Default Re: drag kit fuel system (94goldjungsr)
no.
and how do you "tune" the drag fuel system? heh
Old Jun 4, 2002 | 05:07 PM
Mr. Softee's Avatar
Default Re: drag kit fuel system (dustin)
hmm.. good point laff. well, tune hte s-afc hack ?
what would you recommend for a drag setup to be run at 9 or 10 psi... that doesn't come with the kit
sam
Old Jun 4, 2002 | 05:08 PM
dustin's Avatar
s-afc hack + dsm injectors will do it....
but the FMU won't ..
Old Jun 4, 2002 | 05:19 PM
Mr. Softee's Avatar
cool. i was considering the drag kit, but i'd love to do a custom kit. I'm just concerned about not having all the fittings, hoses, etc... all those little things.
your thoughts?
Old Jun 4, 2002 | 05:22 PM
dustin's Avatar
if you don't have much first hand turbo experience, get a kit
Old Jun 4, 2002 | 05:35 PM
Mr. Softee's Avatar
fair enough. i've done hte na route with jun3s, and 12:1, its turbo time, never had one though.. sounds like a kit is a better option for me.
sam
Old Jun 4, 2002 | 06:50 PM
Ben Huynh's Avatar
I disagree. I've tested the DRAG fuel system up to 11psi on a stock LS.
Old Jun 4, 2002 | 07:03 PM
dustin's Avatar
Default Re: drag kit fuel system (ben@importparts.com)
heheh, ben we all know what fuel pressure looks like @ 11psi on the drag fuel system... although the pump never actually gets to the pressure it should.. which ensures a timley death for the pump and an eventually broken motor
Old Jun 4, 2002 | 07:13 PM
Ben Huynh's Avatar
Actually the pump held up pretty well and the A/F ratio was still a little on the rich side. I agree that the fuel pressures at 11psi are astronomical but the question was whether the DRAG fuel system would be able to support 9-10psi. From my experience, it has been able to.
Old Jun 5, 2002 | 06:56 AM
dustin's Avatar
Reliably? hehe ... it's your motor
FASTFIDDY
Jun 21, 2006 02:35 PM
Prelude Vtec 23
Jul 2, 2003 04:49 PM
TruePlayaz114
Mar 25, 2002 12:24 PM
DIRep972
Jun 17, 2001 04:49 AM
