Turbo integra running crazy rich after engine block replacement w/ same specs
I have an integra that I bought a while back it ran great was turbod pushing around 460 on 15 or so pounds of boost, it ended up cracking a sleeve so I got the motor redone and everything's almost exactly the same as it was same tune same setup so it should be running close to where it was but it's not it's running crazy rich reading 10-10.5 on the wideband with 45 fuel pressure
re: Turbo integra running crazy rich after engine block replacement w/ same specs
Get a proper retune before you damage your new block.
Just because the old and new specs are the same doesn't mean everything will be the same with the tune.
Re: Turbo integra running crazy rich after engine block replacement w/ same specs
My cousin hooked up his hondata on it and threw a basemap on it and it's running way better gonna upgrade from chrome to hondata and go get it dyno tuned this week sometime
