TURBO INSTALLED FINALLY, 1 PROBLEM
Old Feb 4, 2002 | 05:41 PM
intekragsr's Avatar
Default TURBO INSTALLED FINALLY, 1 PROBLEM
There is a little smoke coming outta the center of the turbo......what could this be????????? help wquick
thanx
Old Feb 4, 2002 | 05:46 PM
GSRrR's Avatar
Default Re: TURBO INSTALLED FINALLY, 1 PROBLEM (intekragsr)
From the compressor side?
Old Feb 4, 2002 | 05:51 PM
intekragsr's Avatar
Default Re: TURBO INSTALLED FINALLY, 1 PROBLEM (GSRrR)
i ccant tell :/ and when i drive it.....the blow off valve barely goes off....do i tighten it or soften it?
Old Feb 4, 2002 | 05:54 PM
JM Performance's Avatar
If the turbo is just installed, it'll smoke for a few days. Its just the oil burning off. Dont worry unless the smoking persists, or starts smoking a lot!
Old Feb 4, 2002 | 06:13 PM
threatcon13's Avatar
New User
soften
Old Feb 4, 2002 | 08:01 PM
maxim's Avatar
You'll get that for a while maybe a day or so.. It's just the oils that are on the turbo.
Old Feb 4, 2002 | 08:12 PM
GruvyTune's Avatar
New User
Default Re: TURBO INSTALLED FINALLY, 1 PROBLEM (maxim)
if it keeps smoking you may have an oil leak like i had with my new turbonetics. i pray for you that it isn't the case
Old Feb 4, 2002 | 08:17 PM
MiraiZ's Avatar
my car smoked from under the hood like a drunken man with a Cuban cigar for like three days! But I noticed it was coming from the outside of the manifold and turbine so I figured it was just oil and dirt, and all the WD-40 we sprayed on the dump tube to get it in...everything is okay now....now to getthis damn thing tuned!!!!
Old Feb 4, 2002 | 09:22 PM
Total'd GSR's Avatar
New User
Default Re: TURBO INSTALLED FINALLY, 1 PROBLEM (GruvyTune)
GruvyTune... nice setup! Have you been on a dyno? What kinda hp numbers are you pushing?
Old Feb 5, 2002 | 03:54 AM
GruvyTune's Avatar
New User
Default Re: TURBO INSTALLED FINALLY, 1 PROBLEM (Tanabe'd GSR)
don't ask...its about as fine tuned as a ***** on crack. I am planning on getting it tuned better very soon. I know i am running way rich right now.
smoovy
Apr 19, 2009 11:09 AM
ProjectEG8
Jun 19, 2007 09:59 AM
hoggy
Jul 21, 2004 08:06 PM
01ITR#700
Aug 7, 2003 06:25 AM
whagkangmakulet
Oct 15, 2001 07:43 PM
