Can't lean out enough at idle ???
Old Oct 7, 2003 | 09:52 AM
bumpin_bass's Avatar
Default Can't lean out enough at idle ???
Hey I have a B16a2 with Revhard Stage 2 kit running 8psi now. I am using the VAFC, 450s, Vortech FMU, and Missing link. I have the VAFC at -50 at idle and it is still really rich; how can I lean it out more. Emissions is coming up and the guy at the dyno said it won't pass how it is. I can smell gas fumes at idle sometimes. Let me know what you guys have done or any other ideas that might work. Thanks
Old Oct 7, 2003 | 09:53 AM
KC GSR's Avatar
Default Re: Can't lean out enough at idle ??? (bumpin_bass)
and you are using the fmu and missing link because...?
Old Oct 7, 2003 | 09:55 AM
Default Re: Can't lean out enough at idle ??? (KC GSR)
Tuned it that way. Only adds fuel under boost right?
Old Oct 7, 2003 | 10:08 AM
stackz's Avatar
at the jetties fishin'
Community Builder
you still have the cat on and you smell gas at idle??
try lowering the fuel rail pressure some and did you ever stop to think that maybe you don't need that big of injectors....
just because one guy's got a B16a2 and no problems with it running the hack and 450cc jets doesn't mean you won't....
Old Oct 7, 2003 | 01:52 PM
speedworks's Avatar
Default Re: Can't lean out enough at idle ??? (stackz)
just lower your fuel pressure.
Old Oct 7, 2003 | 02:00 PM
drvfast's Avatar
get rid of the fmu your are running really rich you don't need the fmu running the hack
Old Oct 7, 2003 | 02:15 PM
ghettocrxsi's Avatar
Default Re: Can't lean out enough at idle ??? (drvfast)
With the Vafc you dont need the missing link or fmu. Get rid of both of them
Old Oct 7, 2003 | 03:29 PM
Default Re: Can't lean out enough at idle ??? (ghettocrxsi)
My ecu throughs codes when I don't use the Missing Link. What fuel pressure should I run, rough estimate? The car isn't rich throughout the rest of the RPM band just below 2k. Yeah I can smell fumes after the cat. With stock injectors it was leaning out after VTEC hit.
Old Oct 7, 2003 | 04:38 PM
ttt
Old Oct 7, 2003 | 05:12 PM
m R g S r's Avatar
Just take off the missing link and the fmu and see how it runs.
Old Oct 7, 2003 | 05:21 PM
Default Re: Can't lean out enough at idle ??? (m R g S r)
any other ideas? ECU throughs map code if I don't use missing link.
Old Oct 7, 2003 | 05:51 PM
civictypenos's Avatar
ok,my suggestion,get rid of the fmu,then drop your fuel pressure down,then lean it out witht he vafc.
im still using my missing link with 370's,i dont run the hack and my car runs like a stock turboed car.no bogging,no hesitation whatso ever.id keep the link in there and take it to a dyno to get it tunned.you just dont need a fmu and 450's at the same time.fmu's are for thouse who try to run stock injectors.
Old Oct 8, 2003 | 10:51 PM
Someone said I could retard the timing and make sure my spark plugs have a small gap? What gap should I use? I have the ngk bkr7e's.
Old Oct 9, 2003 | 04:06 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bumpin_bass &raquo;</TD></TR><TR><TD CLASS="quote">Someone said I could retard the timing and make sure my spark plugs have a small gap? What gap should I use? I have the ngk bkr7e's.</TD></TR></TABLE>
.28 w/ stock igntion or .30 w/ aftermarket igntion.
Old Oct 9, 2003 | 05:34 AM
genop's Avatar
Are you sure that your vafc is hooked up right? You shouldnt throw a map code at 8 psi as long as your settings are correct....
Old Oct 9, 2003 | 09:12 AM
Default Re: Can't lean out enough at idle ??? (genop)
yeah the VAFC is hooked up right.
Old Oct 9, 2003 | 09:20 AM
VTC_CiViC's Avatar
FMU + 450's = LOTS-O-FUEL... that's waaaaaaaaaaaaaaaay too much fuel for 8psi. Ditch the FMU and run the AFC alone, or ditch the 450's for some 310's.
89dxhunchback
Sep 7, 2003 07:16 AM
CBR600OnTop
Feb 28, 2003 09:54 PM
blmracing
Nov 21, 2002 06:09 PM
Turbo_Si
Jul 26, 2002 04:19 PM
4gvtec
May 19, 2002 09:18 AM
