turbo and idle problem
Old Sep 3, 2007 | 05:26 PM
b16a4's Avatar
Default turbo and idle problem
Guys i have an idle problem that i cannot figure out,
Do you guys think its safe to boost anyways?
Old Sep 3, 2007 | 05:36 PM
Chris Tune's Avatar
Default Re: turbo and idle problem (b16a4)
get the car running normally first... then do anything else
Old Sep 3, 2007 | 06:05 PM
OLD_HATCH's Avatar
Default Re: turbo and idle problem (Chris Tune)
depends on what your idle problem is. if its somethign as simple as a bad cold idle valve that makes your idle lopey it shouldnt matter much. more info.
Old Sep 4, 2007 | 02:22 AM
b16a4's Avatar
Default Re: turbo and idle problem (OLD_HATCH)
im not sure what is causing the bad idle
Old Sep 4, 2007 | 06:33 AM
batboyvaj's Avatar
check for vac leaks
Old Sep 4, 2007 | 11:22 AM
RCautoworks's Avatar
Little more explanation of whats going on with the idle please.
Old Sep 4, 2007 | 04:24 PM
b16a4's Avatar
Default Re: turbo and idle problem (RCautoworks)
My idle fluctautes on cold startup, about 500-1500rpm.
When it is warm, does it about 850-950ish rpm.
You can hear it surging.
Put on a different Throttle Body
Installed a Walbro Fuel Pump
Intalled a Aeromotive FPR.
Used Another IACV.
Changed Fuel Filter
Changed Plug Wires
Changed Plugs
Vaccum Hoses are good [used carb cleaner on them]
Tps is set to .45 Closed Throttle
Used 2 Other Stock ecu.
Please help me fix this guys
Old Sep 4, 2007 | 04:48 PM
Sounds like a vacuum leak, you try looking into the fast idle air valve ?
Old Sep 4, 2007 | 05:10 PM
b16a4's Avatar
Dont got one of those FITV under my Tb.
I sprayed water all over the engine bay and didnt notice much
Thanks for your help so far
Old Sep 4, 2007 | 06:06 PM
95dc2teg's Avatar
what are u tuned on? crome? i heard that tuning on crome could cause a little surging idle like that? correct me if im wrong. just what ive heard.
Old Sep 4, 2007 | 07:31 PM
Mr.Death's Avatar
Default Re: turbo and idle problem (95dc2teg)
It could be a leaky intake mani gasket, tbody gasket.
Old Sep 5, 2007 | 02:34 AM
b16a4's Avatar
Default Re: turbo and idle problem (Mr.Death)
im not boosted as yet, i will be soon....
stock honda ecu
Old Sep 5, 2007 | 01:15 PM
95dc2teg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16a4 &raquo;</TD></TR><TR><TD CLASS="quote">im not boosted as yet, i will be soon....
stock honda ecu</TD></TR></TABLE>
ahh well that throws my idea out the window!
Old Sep 5, 2007 | 01:47 PM
b16a4's Avatar
This is what i did,.....
sprayed water from a water bottle arround the engine,
i did not notice any difference, also could be that my exhaust is too loud.
Tightened up the nipple/vaccum fitting from my aeromotive fpr , re tightened the intake manifold bolts... top side only.
and took out the pcv valve, and blew both directions on the valve.
I heard a very slight rattle from the pcv, im not sure if its supposed to rattle more?
Now upon doing that, its noticeable less surging...
what you guys think?
Old Sep 5, 2007 | 05:12 PM
b16a4's Avatar
can injector o rings cause a leak?
i have noticed one of my injectors have a hair line crack
Old Sep 5, 2007 | 05:14 PM
Schister66's Avatar
Man U FTW
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16a4 &raquo;</TD></TR><TR><TD CLASS="quote">can injector o rings cause a leak?</TD></TR></TABLE>
that's where my vac leaks were....all 4 of them had bad seals
Old Sep 5, 2007 | 05:18 PM
b16a4's Avatar
Default Re: turbo and idle problem (Schister66)
thanks buddy
Old Sep 5, 2007 | 05:19 PM
b16a4's Avatar
was it the top seal or bottom seal?
bigger or smaller?
Old Sep 5, 2007 | 05:23 PM
b16a4's Avatar
also can a big exhaust leak cause that problem?
dlncooke
Honda Fit
Apr 7, 2013 08:05 PM
jdm4drSi
Apr 6, 2007 08:19 AM
toyzbus
Mar 15, 2005 11:55 AM
CRX-SIR
Sep 20, 2004 06:00 PM
Tw1n Turb0 Z
Oct 18, 2003 07:23 PM
