Turbo help...Thread is a little long.
Old May 19, 2006 | 08:21 AM
UncivilB18C's Avatar
Default Turbo help...Thread is a little long.
Ive got a 93 hatch, gsr, garret t60, ext. wastegate, 450cc dsm inj., walbrol 255, aem rail and regulator. Car was originally tuned at 12 psi using chrome. Lowered boost to 9psi and had it retuned as a base map. It has been through 9 programs now, and it is bounceing off rev limiter at 4800. It only does this in my car, others its fine. Open too any suggestions no matter how dumb, as long as they dont say go back to the shop. Its a long *** drive. Please help.
Old May 19, 2006 | 10:19 AM
ham's Avatar
ham
Default Re: Turbo help...Thread is a little long. (UncivilB18C)
its CROME and if there is no codes or nothing else changed then its obviously a bad burn.
Old May 19, 2006 | 03:15 PM
qfast817's Avatar
Default Re: Turbo help...Thread is a little long. (ham)
do you have any shorts in wiring? also does crome have a 2 step??
Old May 19, 2006 | 03:22 PM
Jay_Sensing's Avatar
Crome has a two step but it is controlled by the VSS. Unless his speedo isn't working, that can't be it.
I would think bad burn as well.
Old May 19, 2006 | 03:24 PM
SOHC_MShue's Avatar
yea i would disable any 2 steps. If the speed sensor doesn't work then that will give you an early rev limit.
Old May 19, 2006 | 05:07 PM
Thank you. My VSS lights kicks on and off. THat must be the fuel cut. Makes sense. Once again, THANK YOU.
blackeg
Engine Management and Tuning
10
Aug 19, 2009 07:40 AM
gsrturbohatchy91
11
Nov 23, 2008 08:32 PM
Car Tweaker
Apr 13, 2008 05:57 PM
lsrcrvtec
Apr 9, 2007 02:01 AM
slotec
Sep 26, 2005 08:46 AM
