Turbo help
Old 02-04-2004, 04:18 PM
l3owen's Avatar
Default Turbo help
i am just starting to get into force induction and dont know much about brands, i wanted to know some good turbos for my gsr. i want to keep power at 7-9k rpm and have it be good for at lest 400 hp. any info would help thanks.
Old 02-04-2004, 04:21 PM
New User
psileepR's Avatar
Default Re: Turbo help (l3owen)
Welcome.
Browse through our archives there's a wealth of information there.
Use the SEARCH button on the top right corner.
Happy reading
Old 02-04-2004, 04:33 PM
l3owen's Avatar
Default Re: Turbo help (psileepR)
i checked i was looking for more info also like what t3/t4 ment and what models of each brand would meet my hopes
Old 02-04-2004, 04:40 PM
jmagner's Avatar
T3/T4 is a hybrid turbo with a T3 turbine section and a larger T4 compresser section. Everything your going to need to know has been covered at some point on these forums so use the Search button as much as you can. Be sure to check the archived topics as well when searching. Try an archive search on 'Turbocharging' for a place to start. Good Luck!
Old 02-04-2004, 05:06 PM
l3owen's Avatar
Default Re: Turbo help (jmagner)
many thanks any personal fav.
Old 02-04-2004, 06:40 PM
jmagner's Avatar
When setting your horsepower goals for a daily driver, you want to be able to achieve your whp goal under 12 psi, generally. With this in mind, you'll want to find a turbo that will make your desired numbers around that psi. I haven't searched much on this, but I'm pretty sure you won't be able to achieve 400whp at 12psi (someone plz correct me if i'm wrong here). Most t3/t4 turbos are very capable of over 400whp when the boost is increased, so you'll be able to do that when your at the track or when your car is feeling slow Any favorite turbos? I don't really have an opinion but I'd stay away from no-name turbos you can find on Ebay. I hope this helps!
Old 02-04-2004, 06:49 PM
b18b1hmtlove's Avatar
you want 400whp but do you expect to build the block to make that?
If you only want 300whp or something like that, buy a turbo for that much whp. if you actually plan on getting to the 400whp range i suggest
.63/.60 T3/T4......
Im sure someone will say some precision sc61 because everyone is on the precision bandwagon now.
.63/.60 T3 should def allow you to make 400whp and spool very nicely for you. only getting boost at 7-9k is just stupid though so i didnt take that into account
Old 02-04-2004, 07:01 PM
l3owen's Avatar
Default Re: (b18b1hmtlove)
YES THE BOTTEM IS FULLY BUILD
Old 02-04-2004, 07:12 PM
grndcont's Avatar
try looking at the t3/to4e, 57trim, stage 3 comp wheel, .48 or .68 turbine a/r. i know you might not know what that means, but it will give you something to reference you search off. don't forget "how to read compressor maps" beware-everyone has there favorite, take everything with a grain of salt. unless it's arturbo talking.
Old 02-04-2004, 07:17 PM
RedTegLS's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18b1hmtlove &raquo;</TD></TR><TR><TD CLASS="quote">Im sure someone will say some precision sc61 because everyone is on the precision bandwagon now.</TD></TR></TABLE>
You dont think there is a reason for that do you? Every setup I have ever seen that is using an SC61 is making GOBS more power than most other turbos. All I have to say is b18cx...............
Old 02-04-2004, 07:21 PM
Default Re: (RedTegLS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RedTegLS &raquo;</TD></TR><TR><TD CLASS="quote">
You dont think there is a reason for that do you? Every setup I have ever seen that is using an SC61 is making GOBS more power than most other turbos. All I have to say is b18cx...............</TD></TR></TABLE>
Looks like someone is on the bandwagon.....
On subject, T3/t04e .63/.60 with a 57 or 60 trim. Enough said.
Old 02-05-2004, 06:18 PM
l3owen's Avatar
so precision is a good brand? or is it hype
Old 02-05-2004, 06:22 PM
l3owen's Avatar
i know this will make me sound bad but can i keep my A/C??!?
Old 02-05-2004, 07:02 PM
you can keep your A/C. I'd suggest a Cast Sidewinder with a .63/.60 T3/t04e. And the big boy 3" DP.
Otherwise id suggest a Inline Pro w/ a .63/.60 w/ a 2.5" DP
Easiest setup, a simple log manifold w/ the same turbo and a 2.5" DP
Old 02-06-2004, 11:03 AM
l3owen's Avatar
Default Re: (l3owen)
precision hype or good??
Old 02-06-2004, 11:11 AM
b18bturbo's Avatar
its not hype its good stuff.
Old 02-06-2004, 11:19 AM
DaX
DaX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by l3owen &raquo;</TD></TR><TR><TD CLASS="quote">i know this will make me sound bad but can i keep my A/C??!?</TD></TR></TABLE>
Ac retention is a must for me. Lovefab and others make this possible.
numbinside
11-20-2004 03:53 PM
steebypue
03-09-2004 07:20 AM
prelude9384
03-05-2004 07:04 PM
nochance
07-29-2003 07:50 AM
Quick Reply: Turbo help
