turbo help
Old Feb 12, 2006 | 06:06 PM
tegman85's Avatar
Default turbo help
which should i need to replace first on my 93 turboed civic, only pushing 10psi, injectors or fuel pump, and does yall know what hp is limited to on the stock ones.
Old Feb 12, 2006 | 06:10 PM
Soccerking3000's Avatar
Default Re: turbo help (tegman85)
well the stock injectors max out at around 210ish whp, and the 10psi is irrelevant without knowing the size of the turbo...
EJ8 GSR-T's Avatar
if you are running 10 psi on a stock motor with stock injectors and fuel pump, assuming that since its a 93 its got a **** load of miles on it...i would forget about upgradeing and start saving for a new motor!
Old Feb 12, 2006 | 06:12 PM
Default Re: turbo help (userdead626)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by userdead626 &raquo;</TD></TR><TR><TD CLASS="quote">if you are running 10 psi on a stock motor with stock injectors and fuel pump, assuming that since its a 93 its got a **** load of miles on it...i would forget about upgradeing and start saving for a new motor!</TD></TR></TABLE>
lol why is that?
Old Feb 12, 2006 | 06:19 PM
EJ8 GSR-T's Avatar
Default Re: turbo help (Soccerking3000)
well 10 psi on a motor with a lota miles on it.....depending on how its driven i think he could easly throw a rod, then its bye bye
Old Feb 12, 2006 | 06:21 PM
lol i know i was refering to your situation...
Old Feb 12, 2006 | 06:24 PM
EJ8 GSR-T's Avatar
haha well i had a turbo d series with 90k on it....boosted it to 11 psi and lated about 2 weeks....then threw a rod...through the block and cylinder wall....deff fucked my **** up!
Old Feb 13, 2006 | 04:02 AM
tegman85's Avatar
well when i want info on your past engines or something like that ill ask for it, but i just wanted my question answered. its not mine, its my friends and we had an argument about what got maxed out first(like which you would have to replace first), i said injectors and he thinks fuel pump.
tegman85's Avatar
Default Re: (tegman85)
oh yeah, its a t3/t4
Old Feb 13, 2006 | 06:52 AM
well of course the injectors... and no need to be an ***
Old Feb 13, 2006 | 08:51 AM
tegman85's Avatar
thanks man, just needed a second to convince him
thanh4o8
Feb 6, 2009 10:53 AM
Pr0j3ctxH@tchx90
Apr 19, 2007 02:26 PM
Ruben19
Jan 27, 2006 12:48 PM
discrete
14
Feb 19, 2005 04:58 AM
yusoslo
Mar 23, 2004 01:54 PM
