will motor blow on stock internals?
with a b16 JRSC'd will it blow my motor on a 10 psi pulley on stock internals? and if someone can give a brief list on parts to help motor not blow...
thanks
thanks
Re: will motor blow on stock internals? (Pr0j3ctxH@tchx90)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pr0j3ctxH@tchx90 »</TD></TR><TR><TD CLASS="quote">with a b16 JRSC'd will it blow my motor on a 10 psi pulley on stock internals? and if someone can give a brief list on parts to help motor not blow...
thanks</TD></TR></TABLE>
chipped ecu
chip burner
datalogging capabilities
wideband
tuner
chipped ecu
chip burner
wideband
tuner
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pr0j3ctxH@tchx90 »</TD></TR><TR><TD CLASS="quote">thanks....is it good to get fuel pump, rail, injectors also?</TD></TR></TABLE>
stock honda rail and reg can handle 300whp...so you should be fine.
but get a walbro 255 pump and some 550cc injectors and have it tuned
Re: will motor blow on stock internals? (CivicVX94)
i havn't did much research on SC's ..is it hard to switch the pulleys and i will be fine running 6psi pulley for daily driving ?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pr0j3ctxH@tchx90 »</TD></TR><TR><TD CLASS="quote">i havn't did much research on SC's ..is it hard to switch the pulleys and i will be fine running 6psi pulley for daily driving ?</TD></TR></TABLE>
I've personally never worked on a sc, but from what i hear, changing out the pulleys isn't fun and prolly not something you want to do often.
and as long as it's tuned you'll be fine at 6psi
Re: will motor blow on stock internals? (BoostedEG6)
i cant PM yet ..this account is still less than 5 days old..where is that located at?
back to orig. subject, is there anyone that runs a 10 psi pulley on a b16, what all mods are done to keep the engine from blowing? and will i have to do anything special to put in my EF or will it fit without any special mounting? thanks
i ♥ my honda
Global Mod
Global Mod
Just get it tuned! Contact Tempest, they can get you everything you need. There located right by MIR.
Re: will motor blow on stock internals?...Tempest Racing (White Smoke)
have you got anything installed there? if i take my car down with the stock b16...and my SC setup or turbo setup.whichever i choose...they can install it and tune it and i could pick it up in a cpl weeks? how are the prices for installation and tuning..on the website it just says call...but i dont want to call cause i wont need to go there til around winter?
You need to do a lot of reading. You're planning on your first car having a supercharged B16? If you ease into things and learn how to do some stuff yourself you won't have to have things installed for you, you'll save money, and you'll want a turbo, not a supercharger.
i ♥ my honda
Global Mod
Global Mod
Re: (nonvtecD)
Once you done with your trial period you can PM BoostedJeff or Turbo-charged and ask them about pricing and such if you don't wanna call. Joe does top notch work! I will PM them both for you now and point them to this thread.
Re: (White Smoke)
i STRONGLY suggest a good turbo system over the JRSC kit.....i can promise you that you will be much happier, make more power, and make the power safer.
feel free to give us a call either me or jeff can help you out with your whole project.
Re: (Turbo-charged)
alright....im going to go with turbo... i will post more when i order my motor and start piecing together my turbo kit..thanks for all the help
4gencivicef9
06-30-2007 01:19 PM
