turbo help
Old Jul 4, 2005 | 04:16 PM
silly93hatchie's Avatar
Default turbo help
i got a all motor b16 93 hatch running 11.3 getting old.
i wana do a turbocharger set up, but im not sure which motors would take the turbo the best and which i could get the most power from. im hearing b18c has too high compression. ls motors would blow up over 12lbs boost.
any suggestions on which motor to get thats best for turbo, and keep in mine i wana run 15-18lbs or so and i dont mind working the motor to make it happen.
thanks for the help
Old Jul 4, 2005 | 04:21 PM
1995Ex_Sedan's Avatar
https://honda-tech.com/zerothread?id=1024174
Old Jul 4, 2005 | 04:54 PM
numbnuts22715's Avatar
if you dont mind building the engine to make it work.. then any engine would work, but I think a b18c1 would be the best, or even c5, but thatll be a little more expensive.
If you get a b18c1 build it a little, get new pistons and rods.. lower compression, and itll be able to hold more boost.
Old Jul 4, 2005 | 05:18 PM
kasso's Avatar
Default Re: (numbnuts22715)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by numbnuts22715 &raquo;</TD></TR><TR><TD CLASS="quote">if you dont mind building the engine to make it work.. then any engine would work, but I think a b18c1 would be the best, or even c5, but thatll be a little more expensive.
b18b1. why waste $3000 on a stock motor when ur gonna build it up with internals anyway??
TheDocta
15
Aug 13, 2008 06:27 AM
rastaman_ek9
Jan 4, 2005 11:15 AM
HS2G
May 30, 2004 06:11 AM
khmerb0ix7o2
13
Dec 18, 2003 09:06 AM
mipawi
Oct 21, 2002 08:47 PM
