Which is the best way to go?
Down Since Day 1
Re: Which is the best way to go? (khmerb0ix7o2)
Guest
Posts: n/a
Re: (khmerb0ix7o2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by khmerb0ix7o2 »</TD></TR><TR><TD CLASS="quote">gonna get a b18c1 or maybe a b18c5</TD></TR></TABLE>
OH IN THAT CASE YOU HAVE TO.......
We cant tell you what to do. Do you want a daily driver, a strip car, a race car....
actually i am assuming you have a d-series otor.. if that is the case i would say def go forced induction.. but work the motor so you can crank up the boost
Re: Which is the best way to go? (1 point 6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1 point 6 »</TD></TR><TR><TD CLASS="quote">all forced induction motor turbo built vtec.
https://honda-tech.com/zerosearch</TD></TR></TABLE>
forgot 2 add superchargered NAWWZ Direct port blowing the welds off of the intake manifold...y0!
use this dude ^^^^
use this dude ^^^^
Re: Which is the best way to go? (strepto)
b series swap + turbo + expensive. if you have a sohc vtec you can build the block and turbo it for much less than the swap cost. boosted sohc vtec on like 8-10 psi will be faster than say gsr mildly built all motor, and if u want faster, just turn up the boost.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by khmerb0ix7o2 »</TD></TR><TR><TD CLASS="quote">I dont know what to do? Which is a better way to go, all motor, or force induction? with an ek</TD></TR></TABLE>
What do you mean by "better"?
Re: Which is the best way to go? (hybrid honda)
first you need to get the engine. Then get it in the car. Then worry about what you are going to do. unless you have alot of money for a full build up before you get it in the car. I am going all motor. But you do what you want. I think that all motor is better but the next guy might think that FI is the way to go. Its all about what you want. They all have there pros and cons.
