turbo has a 2.5" outlet intercooler has a 2" inlet and 2 1/4" outlet
turbo intecooler question am i loosing power or gaining torque????????????
if i put a 2.5" reducer to 2" on
with a 2" pipe of about 2 feet to the intercooler then i got a 2 1/4" pipe coming from intercooler in a bend and a 2.5" charge pipe to my b16
putting a reducer from the 2.5"outlet on my turbo with 2" pipe going to my inetrcooler
am i loosing power ????????
or
should i get a new intercooler with 2.5" inlet outlet and all 2.5" piping??????
or
Who is Mr Robot?
Re: turbo intecooler question am i loosing power or gaining torque???????????? (turbosol_16)
depends.. what are your power goals?
and from the sound of things it sounds like you have a Drag FMIC
Re: turbo intecooler question am i loosing power or gaining torque???????????? (wantboost)
yeas its a drag fmic.....
my motor is built ////im going with big turbo ona small motor.... i want 400+whp on 93 octane...... im making 330whp now with a 60 trim t04e a 17psi im selling the turbo and buyin a gt40r
will the reducer from a 2.5 outlet on turbo to a 2 boost pipe to the intercooler going to rob power or will i gain torque???
Who is Mr Robot?
Re: turbo intecooler question am i loosing power or gaining torque???????????? (N20civicB18)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by N20civicB18 »</TD></TR><TR><TD CLASS="quote">sounds like its time to upgrade your intercooler man</TD></TR></TABLE>
x2
with a gt40r, the drag intercooler will be very restrictive and in-efficient.
x2
what do you need a gt40r for when you can get the gt35r for your power goals.
Re: turbo intecooler question am i loosing power or gaining torque???????????? (Speed Infliction)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Speed Infliction »</TD></TR><TR><TD CLASS="quote">what do you need a gt40r for when you can get the gt35r for your power goals.</TD></TR></TABLE>
You could use a 30R for those goals.
Re: (Got_soy)
t3 exhaust housings are way restrictive compared to a t4... im going with t4 cause just about any t3 power strts to fall off at 6500+ rpm....the bigger turbo the more hp ill make off of pump gas.....i dont mind lag i got a 55 shot of spray...and if i hit full bosst at like 5500 or 6k ill rev it to 10k to make up for it.... then shift a 9 k for all my othere gears once the turbo is spooled....
yeah im changing my intercooler.....anyone in particular you guys are impressed with for the money???
Re: (turbosol_16)
yeah i changed everything already except for the intercooler....
im runnin hondata
1,000cc rc injectors.... walbro 255
all the bolt on mods i can intake manifold, throttlebody, power pulleys
peak boost turbo maifold
38mm wastegate
turbo xs duel stage boost controller
gsr cams for now with stock cam gears
ferra valves with supertechvalvesprings and type r lost motion assemblys
stock port job on head
crower probillet rods
benson sleeves
srp pistons (i will change them when i break the ring lands / normally first thing to go on those) but if seen srps take 500whp plus...... its all in the tune and i trust my tuner...
my car will probably never see race gas... so i think the srp's will do me good on pump gas.... for the next 2 years...
im runnin hondata
38mm wastegate
benson sleeves
Re: (HNLV)
actually you will find gt40 in t3 turbine housings..
T3/GT40 Compressor w/ .82 A/R Turbine Housing
Specs $865.00
http://www.pagparts.com/perfpt...eries
Specs $865.00
1.8T_EG
08-08-2003 06:26 PM
NeXtLeVeL_TyPe_R
04-17-2002 09:38 PM
