turbo gsr time slips
ET- 13.033
Trap speed- 108.43
RT- .569
60ft- 1.946
thats the best one, i was very happy i got that time and escaped without anything broken. that was at 10psi by the way
Pics:
http://y42.photos.yahoo.com/bc/hella...tation&.view=t
Trap speed- 108.43
RT- .569
60ft- 1.946
Pics:
I am located in Houston and own a JRSC ITR and am looking for some advice.
The car is running 5psi, Kamikaze Hdrs, Mugen exh, Short ram intake, Hi-Flo cat, stock inj, Jackson fuel pump, and Apexi VAFC. I am running 50psi static, 80 psi under load, 15 degrees initial and dynoing at 206.4 whp with the air temp at 106 degrees. I am looking for some good guys to help with the car and go to Baytown with.
Please advise
Thank you in advance.
[Modified by crazyitr, 8:13 PM 7/19/2001]
Please advise
GSRev
Please advise
Please advise
Thats a great Run also!! What do you have on your gsr?
[Modified by Type R, 9:59 AM 7/19/2001]
I was fortunate enough to purchase the ITR with the JRSC, but as i understand all the part throttle detonation probs are alleviated with the vafc. The car runs as smooth as silk.
take some air our your slicks (run 11-12psi), make your shocks stiffer in the back, softer up front, and launch a little harder and let it bite a little harder off the line. You got a 12 sec car there bub! With all that in place you should run 12.7's all day!
What are you puttin down to the wheels?
i was running like 14 psi in the slicks. on the first few runs my BTM was retarded at like .5 so i was running 14's. so i'm like damn this is too slow, so i cranked it down, right after i cranked it down 13.3. next run i launched at 6500 13.17. last run launched at 7000 13.03. i couldn't get a decent burnout either, only the left side was spinning. also had half a tank of gas. i plan on getting some race gas next time. Is it true that is u use race gas u can set ur timing at 0?
thanks
thanks
i am waiting for u to show me jay, i think we going up to baton rouge for a dyno on the 11th if u can get ur pullies in by then
and hassan i am waitng to see what ur motor can put out
2K Teggy
Aug 23, 2004 06:21 PM
