Turbo GSR question
Old May 29, 2006 | 09:28 AM
bigdaddyradde's Avatar
Default Turbo GSR question
my buddy is running an FMU with stock injectors on his turbo gsr and when he gets up to about 5k it starts to bog. I was wondering if the problem could be because of feul? Also another thing is that the check engine light is on for a idle air control valve fault. i have been chasing that fault also and have gotten no where. If anyone has any suggestions that would great.
thanks.
Old May 29, 2006 | 09:50 AM
b16adx's Avatar
Default Re: Turbo GSR question (bigdaddyradde)
There are about 5 differer post going on right now covering FMU and fuel problems! But ditch the FMU get uberdata, be happy. DId you replace your IACV and your still getting the code?
Old May 29, 2006 | 09:57 AM
Default Re: Turbo GSR question (b16adx)
yeah i did a search and just came up with posts arguing how bad they suck. I realize the FMU sucks and i relayed the message to my friend but he wants to go the cheap route. I personally run Hondata so i know what your talking about.
As for the idle air control fault, i did swap iacv's with mine and it came up with the same fault. I also ohmed out the wires going from the ecu to the iacv and had good resistance. Also when i unplug it while its running all it does is lower the idle, it doesnt die like its supposed too.
keep em comin
Old May 29, 2006 | 11:51 AM
b16adx's Avatar
Well im stumped! When I unplug mine it doesnt die. Ohwell...did you switch ecus maybe? worth a shot
Old May 29, 2006 | 03:12 PM
geezer_187's Avatar
What did you use as a vacuum source for the fmu? When I first started running mine, I didnt have it hooked to a strong enough source, and I had the same problem as your friend. Once I used my fpr as a vacuum source, it fixed the problem.
Old May 29, 2006 | 04:26 PM
Default Re: Turbo GSR question (geezer_187)
the fmu is hooked up to a vacuum tree so i will try a different source and see what happens.
KaoticBrd
Oct 4, 2007 02:03 PM
EG_GSR
Jan 8, 2007 11:49 AM
BoostedJeff
Oct 26, 2004 06:36 PM
94dxt
Apr 17, 2003 09:28 AM
uneekcrx
Apr 26, 2002 08:16 AM
