Turbo Dyno Graph
a graph of my friends car dynoed at IB
specs:
boost at 1 bar
GSR block, 82mm JE pistons, about 9-9.2:1 comp. stock b16 head, type r cams. modified hks exhaust manifold. t3/to4e .50 a/r not sure what trim. hondata tuned
car went 12.7 @ 108mph in a full bodied/interior 94 integra
i think jeff couldve have extracted a couple of more horses with some sprocet tuning but he didnt touch them at all. the strange part was we tried also at 19psi and it only made about 20 hp more with the same torque output.
anyhow, that is the old setup, this is the new setup
max rev manifold&dp , t3/to4e 57trim, .63 a/r, jg edelbrock manifold
now hoping to make close to 350hp also at 1bar and about 400 at 1.5 bar
[Modified by sparkz, 11:43 AM 7/10/2002]
[Modified by sparkz, 3:36 AM 7/11/2002]
specs:
boost at 1 bar
hmm was that on slicks or radials? With 300 to the ground I would've figured 115 traps.
jeff had the a/f right around 11.8-12.0
to put in perspective, there was another b20 turbo integra that same run which went about 12.5 @ 109 with a 0-60 of 1.8 as well but running 24.5x9x13's. fastest honda/acuras for that day were in the 12.5-13.0 range.
[Modified by sparkz, 12:19 PM 7/10/2002]
Smarter than you
on 24" tall slicks. 0-60 of 1.8 im guesing car with driver is around 2750lbs.
thats your problem. those slicks are too tall. A 23" would prolly work perfect but u might do better with a 22" over the 24.5.
This is my Drag III on 14psi stock bottom end it's also an LS very untuned a/f is way off the chart
yours seems a bit low for the all mighty vtec should go LS
Smarter than you
yes that makes a lot of sense. after looking at the graph, at around 7k-8k the torque is a lot less then what it has a peak.
looks like you need a stage 3 wheel and a bigger exhaust trim - or maybe get rid of the "modified hks exhaust manifold" or whatever that may be...
i made 365whp with a .50 series drag kit...
[Modified by TurboITR, 11:44 PM 7/10/2002]
philipwight
May 19, 2006 11:37 PM
