turbo da smoking?
Just finished putting a clutch and hydro conversion in my gsr swapped turbo da. It sat for around 5 months because i didnt have the funds or time to fix it. Well finally got it back together. Ive only let it go through a few idle cycles. For some reason now it smokes at idle. Its not a blue or white smoke more of a vapor as it dissipates quick. It stops when radiator fan kicks on and starts back up when it turns off. I did a compression test and have 210 across the board. What could it be?
Condensation of exhaust and fuel especially if you have no catalytic converter on the car. no need to drain the tank. let it warm up first to operating temperature, then see what the smoke is. don't panic.
Yep. you're fine. just condensation built up. Its normal, like I said. Let the car warm up, drive, (especially tuned), its harmless. I've had it for years during start up.
